6 disc in dash - no bass?
I have a '99 F-150 that came factory with the single disc cd player. I purchased a 6 disc in dash changer off eBay and it works perfect except I have NO bass at all. My voice literally has more bass than this radio does. Now I know I'm going to need an amp and sub, I've looked for stock stuff but I'm confused, a seller on eBay tore down a 98 Expedition Eddie Bauer and told me it had TWO amps, one hooked up to the stock head unit radio and another on the sub assembly itself.
What will be the easiest way to get some bass back? People are telling me that since the speakers aren't actually receiving any bass, I would have to wire up the sub and amp straight to the head unit itself. I'm so confused it's not even funny...
The problem is that the radio you bought is has the premium sound system and the factory system you have is different. The radio you bought is set up to work with a factory sub and it cuts all the bass from the midrange speakers. I would try and resell the radio and go after market. I have seen this problem many times and ther is no easy way to fix it.
You might look for a wiring diagram for that specific radio, it may have a dedicated sub out already. However, if it were me, I'd sell that one, and get another, if you still want to keep stock, try and find one that is out of a pickup. I have the indash 6cd, add a sub to fill in the lower octave and really love it, thought bout aftermarket, but then decided that I really like the changer in the dash.
Unfotunately if you don't have either of the 2 amps that the expedition has(one inside the dash, the other in the rear 3rd roll passenger side) the bass is pretty much dead. you can try to get these amps off the dealer but that's going to cost a bit, or you can try looking for one on ebay. I would go with an aftermarket indash changer, or get a few subs n a good amp to feed them.
cheapest way out for you would be a new aftermarket indash.
My buddy just bought a 6cd in dash off a Mustang GT w/ Premium Sound and wants to put in in his 2001 F250. Same thing happened where there is no Bass coming out.... He asked me for help and am saerching for options. I am sure someone out there has the pinout for these 6CD decks. A couple of these pins coming from the back of the stereo should correspond to Low Pass Frequency SUB outputs. Pinouts should be available from somewhere without having to seek to the 'Dealer'. They wont disclose the info anyway..........
I have the pinouts for the CDX6 mustang radio.
I have the pinouts for the CDX6 mustang radio. They are fairly simple, however the line-level is so low you need a preamp between it and an amp. I use a harmon/Kardon 2 channel preamp and it works nice. Another big problem is that the bass frequency is set so low that you had better try and use an eq preamp to up the frequency some or have a very powerful amp. red/black is sub neg. brown is sub pos. other is 5-12 volts remote wire and ground. then other wires on the other side of plug are the same if you go across horizontally. on yahoo as mechanic_who_crashed if you need more info
Haoleman
07-29-2009 05:22 PM
BigNiner19
06-22-2009 07:53 PM
3ValveV10Harley
1999 to 2016 Super Duty
09-26-2006 08:14 PM
Fordbyford
11-15-2005 02:18 PM
breakdxwns
11-19-2004 09:23 PM
