What REALLY Keeps Headers From Falling Off?
Old Dec 25, 2004 | 06:36 PM
Boltgunner's Avatar
Boltgunner
OK, the consensus is that the 390 should get headers, but I keep hearing all this and that about header fasteners not staying torqued. Please reply with what works once and for all (if that can be accomplished) when it comes to installing headers correctly. Also, add your suggestions as to what brand header is good for the long haul. Truck is a 76 F-150 Ranger SuperCab 8' bed 2 WD with a 2 BBL 390.
Merry Christmas and God Bless Our Warriors Everywhere ,
Stu
Old Dec 25, 2004 | 07:28 PM
rusty70f100's Avatar
rusty70f100
Well, I just use standard Grade 8 bolts, available at any hardware store. I tighten 'em down real tight, and they stay put. I also use Hedman Headers, and have yet to have an issue with them.
As always, your results may vary.
Old Dec 25, 2004 | 11:35 PM
gtex's Avatar
gtex
FPA Headers. See mine here: http://www.thedreyerfamily.com/69f25...FPAheaders.htm
Use lock-washers. Because I'm running the edelbrock heads and the FPA that use almost 4 bolts per cylinder, I can tighten down with my fingers almost enough to avoid leaking. I didn't put lock washers on before, and they tend to vibrate loose. Even with several missing bolts, no leaks.
Old Dec 26, 2004 | 01:28 PM
whd507's Avatar
whd507
if you have enough clearance, then studs with bronze/nickel nuts. I have done this on several vehicles with great success.
the nuts are available at any cat dealer, but are not cheap.
Old Dec 26, 2004 | 04:16 PM
FERacing66's Avatar
FERacing66
Just use the bolts with lockwashers that come with the headers. Tighten to 30ftlbs and your all set. They should not come loose dont worry about em.
I wouldnt bother with FPA's, unless you want to spend $700 on headers. I got some dynomax headers for Christmas and they work good. They fit perfectly and bolted up with no issues.
Old Dec 26, 2004 | 04:45 PM
Boltgunner's Avatar
Boltgunner
Where'd ya get the DynoMaxes from?
Old Dec 26, 2004 | 05:19 PM
gtex's Avatar
gtex
the Dynomax were a nightmare in my 69 F250, C6 auto with the Bendix box. They may have made some improvements/changes or maybe it's just the Bendix box issue. I never did get mine to fit right or seal. The FPAs: I tighten up by finger, then snug slightly with a small 1/4" ratchet. Never leaked, even with bolts missing. The FPA are pricey (more like $625 or so). But with Ceramic coating and a 3/8" flange, I don't worry much.
the Dynomax I had were also ceramic coated. And probably would have lasted if it weren't for the fitment issues. Maybe, I just got a bad set.
sweetlou1
Oct 23, 2013 03:42 PM
Recoil
Aug 19, 2009 08:03 PM
71FoMoCo
20
May 27, 2003 05:07 PM
Nathan
Exhaust Systems
May 19, 2000 09:03 PM
