WTB Ranger Hubs
Old Oct 4, 1999 | 11:36 AM
doug's Avatar
doug
WTB Ranger Hubs
I have a 1996 Ranger and need to find the autolock hubs for it. The 4 wheel drive won't go all the way in and is hard to get out when it does.
If you have any ideas on where to get aftermarket new ones or a good set of used ones please let me know via e-mail. Thanks in advance.
Doug
Old Nov 1, 1999 | 11:48 AM
BExplorer's Avatar
BExplorer
WTB Ranger Hubs
Have you tryed to clened them up, on my 94 Explorer, one of them was not engaging properly,so I rinsed it clean with solvent and put back bearing grease into it. Since that it's been working fine. On a web site a guy talked about just changing the bearing inside the assembly, if you want to try it I will get you the adress, because I dont have it on hand.
Old Nov 10, 1999 | 04:50 PM
NIGHTRANGER5.0's Avatar
NIGHTRANGER5.0
WTB Ranger Hubs
Ok so you've experianced a weak link. The autos SUCK what i did was replace them with manuals in my 94. They always engage and disengage whaen i want them to. It realy sucks that the wheel has to get at least a 1/2 turn before they'll lock in. What do ya do if your already stuck? Nothing cuz your XXXX (edited by Admin for by passing language filters)ed
Old Nov 10, 1999 | 04:55 PM
NIGHTRANGER5.0
WTB Ranger Hubs
Old Mar 26, 2005 | 09:42 PM
redrangergal's Avatar
redrangergal
Thumbs up Hubs
always remeber,,,nothing is easy grasshopper!!!
ford had an idea...."push a button get 4 wheel drive"
sometimes what looks good on paper...well you get the drift...
all i can say is being one of the fortunate ones i discovered early that
before someone else warns ya i gotta....
WARN HUBS....
MANUAL YES....
4X WHEN U WANT IT YES....
HAFTA GO OUT IN THE SNOW TO DO IT,,,,YES
BETTER THAN THAT HORRID GRINDING NOISE WHEN PUSH A BUTTON DONT WORK....UBETCHA!!!
save yourself alot of grief,,,go on ebay,,,,git er done....
good luck
signed
a happy 94 red ranger xlt v6 4.0 girl
Old Mar 29, 2005 | 07:43 PM
jecp's Avatar
jecp
Talking Manual Hubs
Just replaced the Auto Lockers with manuals. Easy job to do. Cost around $250.00, both sides. Was quoted a price from ford around $380.00 a hub assembly. I was tired of the auto hubs banging, slipping and not fully unlocking. I miss the "conveinance" of flipping a switch or lever from inside the cab, but I feel better knowing when I need 4WD, it will be there.
Old Apr 1, 2005 | 07:19 PM
redrangergal
rumble on!!!
and remember "leave nothing behind other than tracks!"
4X with a conscience!
ciao...
Old Apr 2, 2005 | 02:25 PM
Jason96's Avatar
Jason96
I also had the same problem with my 96 Auto hubs. Changed them out with Mile Marker Manuel Hubs and the conversion kit at Autozone ($161.00) and had Midas install them ($75.00). They work awesome especially for my hunting retreats in Arkansas.
Old Apr 3, 2005 | 05:05 PM
Peter94's Avatar
Peter94
GOt a pair at a junkyard for 60 bucks, then 50 for the spindle nuts, EXTREEMLY easy to instal if your a little bit mechanically inclined.
