need help to I.D. this computer
Old Dec 24, 2004 | 06:05 PM
mauicruza's Avatar
mauicruza
can someone tell me if this EEC-IV is speed-density or MAF. It's out of a 88 MKvii 5.0 I think. thanks for any response
Old Dec 25, 2004 | 05:19 PM
EPNCSU2006's Avatar
EPNCSU2006
What are the numbers on the label? Not the part number, but the catch code, and the lettering in the lower left corner. It should either be SD-EFI, MA-SEFI or SD-SEFI from what I remember. The catch code is the big letters and numbers - for example, A9L.
Old Dec 25, 2004 | 11:45 PM
LxMan1's Avatar
LxMan1
If it's out of a Mark VII, then it is speed density with sequential injection like a Mustang, not batch fired like a TownCar/crown Vic/Truck/T-Bird/Cougar.
Only the Mustangs and Mark VII's got the SEFI along with hyd.roller cams, but the Mark's got speed density while 88 California only and 89-up Mustangs got MAF.
Old Dec 26, 2004 | 03:03 AM
mauicruza's Avatar
mauicruza
thanks guys for both responses. I think this is the catch code-DX3. If this is as you say s/d but seq.fire, is it a pretty good system for an early bronco swap. I know a mass air is much better but It's hard to find a decent one in my area.
thanks ,mike
Old Dec 26, 2004 | 04:31 AM
dsldandually's Avatar
dsldandually
Its very easy to convert a Speed Density to MAF all you need is the harness and computer then you can do any mods you want (within reason) and it will still run.
Old Dec 26, 2004 | 07:58 AM
EPNCSU2006's Avatar
EPNCSU2006
http://fordfuelinjection.com/index.php?p=17
See on those labels there is the SFI-SD and the other one is SFI-MA . SFI is sequential injection; SD means speed density and MA is mass air. If it is EFI-SD, then it is not sequential injecction, but being in a Mark VII, I would think it would at least be sequential, since it is not mass air. That will tell you if it is sequential or not.
jseim44
Nebraska Chapter
Apr 29, 2014 08:07 AM
Trulyvintage
1947 and Older Ford Trucks
May 20, 2011 10:40 AM
HiSPL
Testing.....
Aug 19, 2009 05:52 PM
shorebird
13
Aug 7, 2009 08:55 PM
Ford_Six
Nov 9, 2002 08:56 PM
