Accelerating
Old Dec 24, 2004 | 02:09 PM
crossfirer's Avatar
crossfirer
Accelerating
Hi there
Just wondering if anyone out there can give me some ideas to a problem I seem to be having with my 2004 6.0l powerstroke.
The problem is when I start off from a standstill and start accelerating it almost seems like it is flooding itself. I have to work the accelerator and once it seems to catch and take off I'm leaving a trail of black smoke. I'm wondering if this could be a start of an injector problem. I've replaced the fuel filters about 1000km's ago. I have no water in the fuel. And there are only 43,820km's on the truck.
Thanks
Old Dec 24, 2004 | 02:12 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. The members in this forum are very knowledgeable about these trucks; they will eagerly help you…with your question.
To insure a better understanding of how FTE operates, please read the guidelines, and the READ FIRST notes in each forum you choose to visit. I'm sure you'll find plenty of reading and information to surf though.
Enjoy FTE and Happy Holidays
Old Dec 24, 2004 | 02:51 PM
Maxium4x4's Avatar
Maxium4x4
Well, I guess we need more details Auto/manual....past history.......tuner, fuel box...or stock? Need more info so we can direct you some. Build date of the engine, you will find that on the drivers side vavle cover.
If anything else and your not sure, the VIN can be run to find out what has been done.
Old Dec 24, 2004 | 02:55 PM
crossfirer's Avatar
crossfirer
Sorry about that it's an automatic, I have the Edge Juice chip in it. 4" Turboback Magnaflow exhaust, afe air filter. I'll get back to you with the engine build date.
Thanks
Old Dec 24, 2004 | 03:00 PM
Maxium4x4's Avatar
Maxium4x4
No problem, but now we are getting somewhere....... The black smoke is over fueling.....you might disconnect the Edge module and see what it does.
Old Dec 24, 2004 | 04:25 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
If the low boost fuel setting is on a higher position with the Edge, the smoke is normal. Just as Max said, it is nothing more than overfueling, and will get the truck rolling faster. As for the funny-feeling pedal, once again, it is just the nature of the beast- this is what most people refer to as "turbo lag" (with this vehicle, it is both turbo and computer lag). All of them with tuning devices behave in this manor and nothing seems wrong at all.
Keep your foot through the firewall and enjoy your new-found smoke
Old Dec 24, 2004 | 04:44 PM
Daryl Hunter's Avatar
Daryl Hunter
Hi crossfirer,
Looks like you're already getting so good info.
A few questions.
How you are applying the throttle? Does the truck have the flooded feel when you just slowly press down the throttle and roll off the line or does it happen more when you mash down the throttle harder for a faster getaway off the line?
What happens if you hold down the brake pedel and add a bit of throttle to build some boost before you pull away from a stop?
Does it do it when you don't have the Edge installed?
And of course, WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
Be sure to check out the 6.0 Bible…..great reading
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
http://www.backglass.org/duncan/ps60_manual/
…. In the upper right hand corner of your screen check this out PARTS SHOP for all your “trucking” needs
Must read
http://www.clubfte.com/users/monsta/SuperDutyFAQ.html
https://www.ford-trucks.com/forums/s...d.php?t=303583
Enjoy FTE
Old Dec 24, 2004 | 05:31 PM
FTE Ken's Avatar
FTE Ken
Thanks
The Edge Juice is not a chip. There are zero chips for the 6.0 because the 6.0's computer does not have a service port to accept a chip. Chips (such as on the 7.3L diesel) are able to reprogram the transmission as well. The Edge is a fueling module that basically fools the computer into raising injection pressure and doesn't program the tranny, often resulting eractic shifts at the higher settings. We used to carry fueling boxes before Diablo and Superchips had programmers and rejoiced when we could finally drop them.
Old Dec 24, 2004 | 07:43 PM
Maxium4x4's Avatar
Maxium4x4
Info helps
Are you the original owner or buy it like it is?
Did your problem just start or did you just install the Edge Module?
This helps us understand better.
Old Dec 24, 2004 | 09:27 PM
alfama351's Avatar
alfama351
Originally Posted by PSD 60L Fx4
Enjoy your new-found smoke
gotta love that smoke, when it stops smoking it really takes off
Old Dec 25, 2004 | 04:33 PM
crossfirer's Avatar
crossfirer
That overflooding feel happens when I slowly press down on the pedal. When I quickly press down on the pedal, it sounds rough for about a second, then clears up. I found that it did also do it a little bit before the Edge was installed. Now with the Edge installed it is happening more often. Also I did find that when it would start doing this, if I shut off the motor and then started it right back up. It would run great after that. However, more recently I am finding that shutting it off and turning it back on, isn't doing the trick like it used to.
I am the original owner of this truck. I have had the Edge in for around 3 months now. Like I said lately is that I have really noticed the overflooding problem.
Old Dec 25, 2004 | 05:27 PM
Customz's Avatar
Customz
I wish I could blow more black smoke...my stock truck is pretty clean, I can only see the cloud at night. Sometimes a ricer needs their cabs filled w/ thick black choking smoke to let em' know not to pass on the right and cut off superduties. (The darn things sit so low they can't tell how bottle necked traffic can be.)The black smoke I've seen only happens at a standstill. Do the tuners (pred, scmt) do this like the fuel modules?
Old Dec 25, 2004 | 09:45 PM
Daryl Hunter
My SCMT doesn't blow any smoke unless I've been idling for quite a while or doing nothing but my normal 4 miles forth and back to work. Then the first time or so that I really trounce on it it will puff some smoke in 1st gear a time or two.
After that it burns clean and you can't get it to do it at stop lights anymore.
Old Dec 25, 2004 | 09:47 PM
SpartanDieselTech
Former Vendor
I'm glad I don't have the "not enough smoke" problem
Actually, I'm getting a little tired of mine...it smokes taking off from a stop even at very light throttle...MIGHT have something to do with tuning, but who knows
Oh well...I have my new, second rig now...I'll post some pictures on here soon
Old Dec 25, 2004 | 11:21 PM
Maxium4x4's Avatar
Maxium4x4
If you traded in your original truck I hope no one asks for the OASIS.....it probably would put a print out 12' long......or did you keep it....
