Need Help
Old Dec 24, 2004 | 12:30 PM
93flare5.0's Avatar
93flare5.0
Question Need Help
just to give you a heads up i am 17 and have virtually no electronic experience with that out here's my problem
i recently got a 5 inch tacometer from auto meter and i need help installing it, badly.. i got sodor, iron, 12 volt tester i just need help putting it on if any one could assist me with some info that would be greatly appreciated
thank you
oh yea i have a 93 flareside f150 5.0
Old Dec 24, 2004 | 01:01 PM
Nightrain's Avatar
Nightrain
Alrighty, I'll see what I can do in helping you out... First off, if you have the tach handy, tell me how many wires there are, their color(s), and check the manual that came with the tach to see what each of them are for. Once that is posted, I'll walk you through the rest.
Nightrain
Old Dec 24, 2004 | 06:30 PM
93flare5.0's Avatar
93flare5.0
ive done everything else i just need to know which is negative on the coil for the tach to go on... everything else is done and it took me all day lol
Old Dec 24, 2004 | 10:45 PM
Nightrain's Avatar
Nightrain
Well doggone... Then you're down to the easy part!
I have been told that it's the gray wire coming off of the left-hand side of the coil. I haven't looked for mine yet, but you should be able to find it. If you don't know where the coil is, find the distributor on the engine. Look for the plug wire in the center of the distributor cap. Follow that wire and at the end of it should be the coil. Then, you can look for that gray wire coming off of the left-hand side of it.
Good luck! Let me know how it all turns out for ya.
Nightrain
Old Dec 25, 2004 | 07:01 PM
93flare5.0's Avatar
93flare5.0
thanks for that info..works like a dream
thanks alot night
Old Dec 25, 2004 | 07:26 PM
Nightrain's Avatar
Nightrain
Glad to hear that you got it working.
Nightrain
Old Dec 26, 2004 | 10:25 AM
SuperHighOutput's Avatar
SuperHighOutput
A little late but FYI the factory instument cluster w/Tach is a direct replacement for the ones w/o the tach. No wiring mods or changes are nescessary.
Old Dec 26, 2004 | 12:19 PM
Nightrain's Avatar
Nightrain
Thanks for the tip, SuperHighOutput! I haven't installed my aftermarket tach yet, but I think that I would prefer it over a factory unit. No telling what an instrument cluster with a tach would cost at the local pick n' pulls...
Nightrain
