Update on Vibration problem??
Old Dec 27, 2004 | 08:55 PM
cadriver's Avatar
cadriver
Smile
Originally Posted by KEVINS800
sure sounds like the dampener behind the trany or possibly a bad drum brake in the rear??
Yeah, it sounds right Kevin!!
I found some play there, but I wasn't sure if it's normal, I don't know if should
be any play at the dampener???.excuse me!!, is the dampener located
between the trany and the driveshaft????
Old Dec 28, 2004 | 01:14 AM
cadriver's Avatar
cadriver
How can I check to see if the dampener it's ok???, what should I look for ???
Old Dec 28, 2004 | 06:19 AM
KEVINS800's Avatar
KEVINS800
YEA it is between the trany and drive shaft! if there is play then most likly it is bad! i've heard of many of these bad with over 100,000 miles on the 2 wheel drive truck
Old Dec 28, 2004 | 03:51 PM
cadriver's Avatar
cadriver
After removing the drive shaft, does the dampener comes off easy???
any special tools needed??? there is any bearing and seal that should I replace once
I removed the dampener????? Thanks..
2.3l 2w drive.
Alex Bindas
Mar 16, 2014 04:23 PM
nightrunner06
Jul 2, 2013 12:33 PM
BluePitt
Mar 27, 2012 09:06 PM
tao
Offroad & 4x4
Apr 9, 2011 10:52 AM
