COP questions
Old Dec 23, 2004 | 08:07 AM
Piper106's Avatar
Piper106
COP questions
Just had rough running/misfiring engine and 'service engine soon' light on my 4.6L 2001 Expedition. Took into dealer, and COP on cylinders 3 and 4 needed to be changed, $520 to get it back.
Looking at this board looks like problems with the COPs are fairly common.
Some questions;
Are certain cylinders are more prone to this than other cylinders?
Now that two COPs have died on this engine, what is the likelyhood that others will die in the future??
Are there any preventative measures to prevent this from happening in the future??
Any better more durable parts to install next time??
Sounds from other posts like changing the COP on cylinders 4 and 8 are a pain, how bad are the others to change at home?
Piper106
Old Dec 24, 2004 | 11:23 PM
LxMan1's Avatar
LxMan1
Usually 3 or 4 can fail if there is an antifreeze leak from a heater hose that is above them. It gets down into the spark plug pockets and shorts out the coils.
It seems that #4 is the biggest offender due to possible anitfreeze and it is shrouded by the firewall and such and gets hotter than the rest of them.
You may never have another one fail. So far, all of mine are original.
Keep the engine dry and use some dielectric grease on the boots when you change them or the plugs.
Piper106
Dec 26, 2012 06:56 PM
Piper106
Feb 5, 2012 12:30 PM
echo657
1997 - 2003 F150
Aug 2, 2011 03:29 PM
