What Sensor In The Picture? - 88/E150/302
Is this the Throttle Position Sensor? 88 E150 302 V8
https://home.comcast.net/~fishauthority/tps.jpg
TPS Picture 88 E150 302
I think I located it. How do you change that if it goes bad? Looks like a tough fix.
https://home.comcast.net/~fishauthority/atps.jpg
Two screws hold it in place.
Remove screws and remove sensor. If they are hex-head, then a small ratchet should fit in there easy enough.
Don't recall type of screw...
If you did have a problem getting to it, then remove the four bolts holding the throttle body on. Turn the throttle body so you can get to the sensor easier. Shouldn't be necessary to disconnect anything from the throttle body while doing this.
I don't recall having to do that...
dffay
10-25-2007 04:19 PM
mjstef
05-22-2007 10:50 PM
AManAndHisTruck
11-30-2004 05:11 AM
hotrodford_88
05-30-2001 04:05 PM
