98 Expedition Not Getting Hot Enough
Old Dec 22, 2004 | 12:49 PM
mountainman101's Avatar
mountainman101
Work Close To Home Checked Thermostat Ok Dosent Heat Up Fast Enough My Freind Put Cardboard In Front Of Radiator For Winter Is This Ok
Old Dec 22, 2004 | 04:45 PM
xxx609's Avatar
xxx609
Does it come up to normal operating temp other than on your short trip? If not, get it checked out!!! The low coolant temp causes the vehicle's computer to send a rich mixture to the fuel injectors. As the coolant/engine gradually warms up, you progressively reach the optimal engine fuel/air ratio. Rich mixtures are not only expensive (fuel costs), but they can cause premature cylinder/ring wear. Go easy on the throttle if your trips are that short.
7283-F250
New Hampshire Chapter
84
Nov 2, 2012 11:22 AM
grizzly11
31
Jun 25, 2012 09:34 AM
tjdad62
Nov 20, 2010 06:53 AM
MotoraceD
Sep 30, 2004 09:29 AM
96Redstang
Jan 19, 2003 12:22 AM
