pyro question
Jun 22, 2012 | 10:51 AM
pyro question
would it be ok to run a pyro in each manifold for drag racing n sled pulling or is one good enough
Jun 22, 2012 | 10:53 AM
It won't hurt anything. I'd say under extrem conditions one in each manifold is a good thing
Jun 22, 2012 | 06:09 PM
Quote:
Originally Posted by
fordpride
Under what circumstances would you see different egts right to left? not under normal operation.
Jun 22, 2012 | 06:58 PM
Injector failing or fueling to much. Plenum leaking on one head.
Jun 22, 2012 | 11:39 PM
Good point Mike, one for each eye.
OT, are 3" plenum's needed with the s366? Are you going with head studs with your stage 2's?
Jun 23, 2012 | 06:23 AM
I will run 3" SD plenums. By next summer I'll have turbo, trans, push rods, studs,and comp 910 valve springs
Jun 23, 2012 | 09:08 AM
Does the turbo connect right up to 3" plenums?
Jun 23, 2012 | 09:32 AM
You'll have to build your own spyder. I'm gonna cut the hot side off of a SD spyder and use the cold side and build my own hot side
Jun 23, 2012 | 11:18 AM
Alright, thanks! If you run across SD plenums and spyder, let me know. I never look in this sites classifieds, I'll have to do that.
Jun 23, 2012 | 11:56 AM
I can get my hands on a few spyders. And clay has the stock plenums fairly cheap
Jun 23, 2012 | 09:02 PM
Well, if you can, let me know. I'll go check Clay's website. Thanks Mike. What I'm doing is thinking 4 months in advance.
Jun 23, 2012 | 09:26 PM
Jun 23, 2012 | 09:48 PM
Just looked Mike, ouch! Didn't they come stock on the SD's?
Sorry orginal poster, sorta
Jun 23, 2012 | 09:57 PM
Yep the link I posted is for the stock SD ones for 40.00 each
You must have looked at his custom ones.
Jun 23, 2012 | 10:01 PM
