Stud Girdles
Old Dec 21, 2004 | 11:01 PM
1982fordf100's Avatar
1982fordf100
Stud Girdles
At what point do you need stud girdles for the rocker arms? I've seen them before and I would imagine that they help stablize the valve train with high lift cams? Are they just like main girdles for the mains?
Old Dec 22, 2004 | 02:08 AM
mako5972's Avatar
mako5972
Basically they are the similar. They both stiffen up parts that otherwise have flex. The more accurate your valve train events the more power the engine can make. Flexing kills performance. Granted these engines that utilize girdles are high performance engines.
Old Dec 23, 2004 | 08:40 PM
1stF250's Avatar
1stF250
They are used for high rpm motors, most stock motors do not need them.
Old Dec 24, 2004 | 03:43 AM
mako5972's Avatar
mako5972
Mild street engines do not need girdles, it would have to be a real beast to need girdles. Kind of like the engines that get chained down to prevent them from tearing themselves out of the mounts.
Old Dec 26, 2004 | 11:36 AM
stevef100s's Avatar
stevef100s
Actually, it depends on how stiff your valve springs are. As long as there is no spring binding, the high lift itself would not cause the studs to flex. Another reason for girdles, would be if you swap to an increased rocker ratio over stock, which causes more pressure on the studs.
408bronco
Ford Truck Parts for Sale
Jul 18, 2016 09:26 PM
xavier23
May 5, 2011 11:09 AM
jamies460
19
Jun 7, 2008 10:52 PM
bronco521
15
Dec 19, 2006 02:26 PM
FalconStng
15
Aug 14, 2006 06:19 PM
