windsor splayed main caps
Old Dec 14, 2006 | 01:42 PM
bronco521's Avatar
bronco521
has anyone put splayed caps on a stock ford 351w block?was wondering if the main webs are thick enuf for this to have any benefit.
i have heard differing opinions on main girdles but nothing about splayed caps.
Old Dec 14, 2006 | 04:23 PM
Kemicalburns's Avatar
Kemicalburns
i wouldnt, there really isnt that much to drill into. a main girdle would do as good if not better.
Old Dec 14, 2006 | 09:09 PM
WarWagon's Avatar
WarWagon
If you are going to be building enough power that you need splayed caps, I would start with an aftermarket block.
Old Dec 15, 2006 | 08:27 AM
Kemicalburns
warwagon is right on with that. How much power are you lookin at? a standard 5.8 block will handle 500+hp easy.
Old Dec 15, 2006 | 08:50 AM
l-m tech's Avatar
l-m tech
you can use a stud gurdle on the mains and put the lifter valley supports in and the factory block should do just fine.
Old Dec 15, 2006 | 04:11 PM
WarWagon's Avatar
WarWagon
"should" is the key word.............
Old Dec 15, 2006 | 04:30 PM
bronco521's Avatar
bronco521
it's gonna be a afr(205 or 225) 418.i have a windsor block to use.was going to get a dart block but i broke a lifter in my bronco and it chowed the cam.so the money i was planning on using for the dart block is now going into my bronco engine.
i wanted to go 4.125 with a 4" stroke in the dart but most likely will do a 4.1" in the windsor block.
i realize a roller cam & lifters doesn't add up to $2000 ,but i'm sure i'll do other stuff when i have it opened up.
just have to force myself to work more overtime.yuck
Old Dec 15, 2006 | 09:41 PM
WarWagon's Avatar
WarWagon
Is this a bracket motor?
Old Dec 15, 2006 | 11:18 PM
bronco521's Avatar
bronco521
nope.just for fun.i'm not going to say it won't go down the strip a few times but it's just for playing around.
Old Dec 16, 2006 | 07:48 PM
WarWagon's Avatar
WarWagon
I wouldn't go with a 4.1 stroke then. I'd just build a 393.
Old Dec 16, 2006 | 08:19 PM
bronco521's Avatar
bronco521
nope................
Old Dec 19, 2006 | 07:53 AM
scottie2hottie's Avatar
scottie2hottie
You'd need a lot of power in a small block to need splayed caps. I agree with everyone else get yourself a stud girdle. If you want the 4.1 stroke you get it bud! Won't hear me criticize!
Old Dec 19, 2006 | 11:33 AM
bronco521's Avatar
bronco521
thanks.i had just read differing opinions on whether a girdle actually does any good other than hold the parts together when the block splits in two.a windsor block is a fair amount stronger than a 302 block.
i was just mainly wondering if anyone had put splayed caps on a windsor before.it's pretty common practice on the evil bowties.
i run a girdle on my bronco engine.
Old Dec 19, 2006 | 11:41 AM
scottie2hottie
if you really want them i like milodon's kit. they give you the tap, bit, bolts, bit slide(to line up the drill correctly)and caps. My buddy did it himself on his 429 the only tools needed was a drill and the tap wrench. they are well built also. For these small block's i just don't see much of a need. the windsor blocks do hold together better on the bottom end than 302's do.
Old Dec 19, 2006 | 12:01 PM
bronco521's Avatar
bronco521
i hope he had it line honed afterwards.i'll probably just go the girdle/studs route.then if i break it i'll get a dart block.it should hold up for what i will be doing with it.
