Tachometer
Old Nov 12, 1999 | 07:35 PM
Darren's Avatar
Darren
Tachometer
Need some help installing an aftermarket SUNPRO tach on my 96 Ranger, 2.3l, 4 cyl, 5 speed. This is an electronic distributorless ignition and there-in lies the problem. Most of these tachs connect to the negative side of the coil. This system has two coils and when I do connect I get a reading that is way too low. Have been trying to coneect to the negative sides of both the primary and secondary coils. Neither seem to work. SUNPRO said I need to find the wiring designed for the tach. Not much help. Any of you have experience here? Thanks.
Old Dec 5, 1999 | 07:26 PM
Kyle's Avatar
Kyle
Tachometer
You may have to get an inductive pickup or if you rpm's are about half of expected, try hooking to both coils.
Old Mar 13, 2000 | 12:05 AM
ummduh's Avatar
ummduh
Tachometer
Did you get this figured out yet? Anybody else know?
My freind has a 97 2.3 that he's trying to hook a tach up to. No dice as of yet.
Thanks
Old Mar 14, 2000 | 10:32 PM
ummduh's Avatar
ummduh
Tachometer
The tach. lead is a Tan/Yellow wire coming off the PCM. That's as much help as i can give
Old Mar 18, 2000 | 02:08 AM
ummduh's Avatar
ummduh
Tachometer
We (myself and the other guy that posted under my name) traced it down to a tan/yellow wire. The PCM is right underneath the hood, and we plan on snagging it right off of there. No clue as to if we'll need adaptors to get an aftermarket tach working. We'll find out soon.
Matt
Chris (the guy that actually drives the Ranger)
Old Mar 20, 2000 | 02:02 PM
lordconqueror's Avatar
lordconqueror
Tachometer
03trueblue
Aug 26, 2012 09:30 AM
Screamin T/A
Feb 1, 2012 09:09 PM
Nightrain
Oct 6, 2007 10:46 AM
f250rangerexplorer
Nov 18, 2004 07:00 AM
BLaCkSiLo
Electrical Systems/Wiring
Sep 11, 2003 04:58 AM
