Tach Install Question
Old Nov 18, 2004 | 02:41 AM
f250rangerexplorer's Avatar
f250rangerexplorer
I bought a SunPro Super Tach II 3 3/8" and it says i have to connect it to the Negative lead on the coil. What color is this wire? I've never installed a tach so i'm just curious before i start. Where is this wire located? I'm gonna mount it on the column. Any help would be greatly appriciated.
Old Nov 18, 2004 | 06:17 AM
genesee12001's Avatar
genesee12001
On my 76 with a 390, my tach is hooked up to the black one. I hope that helps.
Old Nov 18, 2004 | 07:00 AM
77460f150's Avatar
77460f150
The wire from the tach should be green, hook that wire to the neg. side of the coil (if you have electronic ignition it will say "TACH" on the connector) that wire color is usually green or black, or the coil usually has "BATT" on the top by the POS side, you will want to hook to the other side (NEG) for TACH. -Ed
rowdyredneck
Aug 3, 2013 10:45 AM
Scheol
31
Jun 10, 2011 02:19 PM
imlowr2
18
Mar 25, 2006 10:41 PM
todder53
15
Jan 13, 2004 09:35 PM
oft
Aug 7, 2002 02:50 PM
