Vibrations
Old Dec 21, 2004 | 08:22 PM
Pat_'s Avatar
Pat_
Vibrations
I have a 2004 6.0 with auto trans and 13K miles. I have just started noticing a vibration in the steering wheel, dash, etc with no change in normal commuting.
Any suggestions in what causes this?
Old Dec 21, 2004 | 08:33 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
Be sure to check out the 6.0 Bible…..great reading
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
http://www.backglass.org/duncan/ps60_manual/
…. In the upper right hand corner of your screen check this out PARTS SHOP for all your “trucking” needs
Must read
http://www.clubfte.com/users/monsta/SuperDutyFAQ.html
https://www.ford-trucks.com/forums/s...d.php?t=303583
Enjoy FTE
Have you taken it to the dealer?
It could be simple...like a thrown wheel weight.
Old Dec 21, 2004 | 08:45 PM
huntercgr's Avatar
huntercgr
Also, have the tires been rotated yet? Stock tires? They should be rotated and re-balanced by now. That'd be my first option.
Old Feb 16, 2005 | 09:38 AM
Pat_'s Avatar
Pat_
still have vibration
Well - I'm at a loss for ideas- the truck now has 15K on it - the tires have been rotated and re-balanced and still have issue - I notice it between 65-70 but really it is tied mor to RPM - even at idle. Is anyone else's reveiw mirror distorted from vibration all the time? I've also just had the injector control module replaced and the #2 injector. ($$1600 later - but the warrenty covered it)...I'm wondering if it is engine related and not alignment / tires.
Any suggestions? Pat
Old Feb 16, 2005 | 10:52 AM
huntercgr's Avatar
huntercgr
Unbalanced driveline? Try some searching on this topic, it has been discussed before. Good luck.
Old Feb 17, 2005 | 12:11 PM
Superduper's Avatar
Superduper
Pat, I had an 04 and a bad vibration when accelerating from a stop. I also dicovered a fix by using a piece or two of lead tape (buy from Golf Shop) or even wrapping a stainless steel clamp onto the rear driveline and revolving the clamp to place the extra weight from the clamp screw in different experimental positions to accomplish balance. This worked for me. Cheap!
Old Feb 18, 2005 | 06:11 AM
Adams91's Avatar
Adams91
What I have found to work best no balancing a driveshaft is to leave the hose clamp just loose enough so that it can still rotate arround the driveshaft. After a little driving, the clamp screw will find the best position for balance. After you find where the extra weight needs to be added, I like to remove the clamp and weld a washer on as a larger and more permanent weight.
jjmaas
Jun 14, 2010 02:26 PM
tjames001
2004 - 2008 F150
Nov 8, 2009 05:02 PM
wingset
2004 - 2008 F150
Sep 11, 2006 09:29 PM
1992flareside
Jul 7, 2006 12:32 PM
mdrco
1978 - 1996 Big Bronco
Jun 25, 2000 09:04 AM
