vibration
Old Jul 7, 2006 | 08:01 AM
1992flareside's Avatar
1992flareside
vibration
I have a vibration at 50-55mph .not sure what it could be? I have new ujoints,maybe tire out of balance? Vibration coming from under the cab?
Old Jul 7, 2006 | 08:33 AM
Old_Paint's Avatar
Old_Paint
Haven't bumped anything with a wheel have you? Kinda remote issue, because the OE wheels on this model are quite strong. Raise it one wheel at a time, and check for wobble or run-out. If no wobble on the wheel, look at the tread surface itself while you rotate it. Sometimes, the tires just ain't round no more, especially if they're Firestones. I wouldn't put a Firestone tire on a wheel barrow. If nothing there, get the balance check on the tires. Do all 4 because the suspension and frame on these trucks are quite stiff, and any one of the tires can cause the whole truck to shake like a wet dog.
Old Jul 7, 2006 | 08:35 AM
shooter05's Avatar
shooter05
Could be the bushings on the rocker arms. I have the same type of vibration that I feel right under my feet. I know mine is bushings. I'd check all your bushings as they do break down and things start to wobble.
Old Jul 7, 2006 | 08:52 AM
Old_Paint's Avatar
Old_Paint
Good call Shooter. Totally forgot about having the alignment eccentrics replaced because of wear at about 100K when I was getting new tires.
flareside, notice any strange wear on the inside edges (other than the normal twin I-Beam camber wear) of the front tires? Should be some pretty significant cupping if things are getting loose in the front end. Gonna do those bushings, get some new struts while you're at it.
Old Jul 7, 2006 | 12:32 PM
1992flareside
Had all new b joints ,wh joints and brakes and shocks put on within the last year,never have done the bushing on the truck. I will go check it out . THANKS.
jjmaas
Jun 14, 2010 02:26 PM
tjames001
2004 - 2008 F150
Nov 8, 2009 05:02 PM
wingset
2004 - 2008 F150
Sep 11, 2006 09:29 PM
DeckedoutF150
2004 - 2008 F150
Feb 24, 2004 12:16 AM
mdrco
1978 - 1996 Big Bronco
Jun 25, 2000 09:04 AM
