Leaf Blower!!!
Old Dec 21, 2004 | 07:17 PM
bigexpo's Avatar
bigexpo
Exclamation Leaf Blower!!!
i het you could use a leaf blower for a spercharger just a thought because ive seen it on the internet before
Old Dec 21, 2004 | 08:05 PM
triton_2002's Avatar
triton_2002
Don't believe everything you see on the net.....
Old Dec 22, 2004 | 03:15 AM
mako5972's Avatar
mako5972
ROFLMAO! I hope you are kidding.
Old Dec 22, 2004 | 11:17 AM
FordPerf300's Avatar
FordPerf300
maybe if you were to force air into say...another leaf blowers engine.... but even them, a leafblower doest compress the air much if any.
Old Dec 23, 2004 | 09:44 AM
rallenr1's Avatar
rallenr1
I built one about 8 years ago for my v-6 camaro. used large leaf blower and built custom intake tubing. mathematically it would build 9 psi, but as pressure would build in the intake track it could not build as much cfm's as in a free flow situation so I dont know what it really put out.
Old Dec 24, 2004 | 11:56 PM
FTE Herman's Avatar
FTE Herman
I don't think it feasible, but bless you for the experimentation.
Old Dec 25, 2004 | 01:12 PM
frederic's Avatar
frederic
A leaf blower will generate a lot of flow, however it doesn't generate any pressure worth mentioning. Similar to a shop vac.
Plus, you'd have two aspects of inefficiency... electricity being converted to a rotating force, i.e. the motor, which is 1/2 efficient at best, plus the inefficiency of the inverter, converting 12VDC to 120VAC for the leaf blower, which is 85% efficient at best.
10A leaf blower +15% = 11.5A @ 120V = 1280W
115A required for inverter.
That's an awful lot of loss, for something that won't help very much.
Old Jan 7, 2005 | 01:45 PM
camo4stealth's Avatar
camo4stealth
My leaf blower is rated at 300 cfm. So I would bet that even a 4cyl. Focus needs way more air than that to run.
Old Jan 8, 2005 | 01:59 PM
2000BLK54's Avatar
2000BLK54
You wouldn't even gain 1 hp from a setup like that. See those so called electric "superchargers"? They use a far more powerful motor and flow much more air than a typical electric leaf blower....and those e-superchargers barely create any positive manifold pressure. The power required to build boost at the cfm's the engine requires is far more than any leaf blower can produce.
Old Feb 12, 2005 | 09:25 PM
BigCrzyRdNeck's Avatar
BigCrzyRdNeck
I know a guy who makes turbos for a living and he uses okd shop vac blowers and a electric motor on the go carts he races to get almost 30 hpsout of a 5 hp race block.
Old Feb 13, 2005 | 08:50 AM
frederic's Avatar
frederic
It's very easy to figure out how useless a leaf blower is:
http://www.conweb.com/tblefile/elmech1.shtml
Old Feb 24, 2005 | 07:39 AM
jrocco's Avatar
jrocco
Ultimate E Blower
And here it is!!!
Old Feb 24, 2005 | 08:00 PM
wicky's Avatar
wicky
don't show that to those HonDUH tunerdz. They'll hook 'em up w/ thier 20 Hp stickers to blow the doors off of matchbox cars.
Old Feb 24, 2005 | 10:37 PM
thesprocket26's Avatar
thesprocket26
Dude c'mon! I run like seven of those leaf blowers inline and get like 1,000,000 HP. These things rock! I will sell you my setup for $2000. Give me an email.
Old Mar 25, 2005 | 08:23 AM
vanlohd's Avatar
vanlohd
Where is the air filter? Does the fan in the leaf blower some how magically filter out everything and expell it out the bottom? Is there a scoop in the hood for the top of the blower to draw air in?
I first saw that back when I had a thunderbird...that's on a 4.6L t-bird. I about died laughing when I saw that.
Toro! Toro!
