E-350 engine removal
Old Dec 21, 2004 | 06:49 PM
351M's Avatar
351M
Hey all, I'm wondering if anyone knows of the least damaging way to remove the engine (351W) and tranny from a '95 E-350, The tranny is puking fluid out and the guy might want to replace the engine too, due to high milege and all. Thanks for any help.
Old Dec 22, 2004 | 12:58 AM
351M's Avatar
351M
Any Ideas pfogal?
Old Dec 22, 2004 | 02:27 PM
rclarke's Avatar
rclarke
Tranny removal is very easy on Econoline. It comes out the bottom. The motor is a little harder. Remove grill, ac condensor, radiator, top bar of the radiator support, and throttle body. Attach a lift plate in place of the throttle body and use a boom type engine hoist. As easy as the tranny is to take out the bottom I wouldn't try to pull engine and tranny together although it can be done.
Old Dec 23, 2004 | 05:57 PM
351M's Avatar
351M
Ok, thanks, I was kinda wondering because if he decides to go withy replacing both I was hoping I could just pull them both from the front, either way though.
Old Jan 6, 2005 | 06:29 PM
wolfmanagh's Avatar
wolfmanagh
I had pulled both out together on a 78 e150 at least 10 years ago. I think it was a 351 but I can't remember for sure.
No I can say I would not recommend even trying to do so. Cause this van was sent to the bone yard after I got the good out. So I didn't care and did a lot of cutting on the body to make it come out this way. I'm sure I wouldn't have been able to do this without cutting as much as I did.
Also it was fun to do it this way.
Old Jan 6, 2005 | 09:35 PM
Mustang 5.0's Avatar
Mustang 5.0
I took the engine and trans out as a single unit thru the front in my 89 e-150 and put a 351 back in the same way.
Old Jan 7, 2005 | 07:12 PM
351M's Avatar
351M
Ok, thanks, As long as I have the chioce, I'm gonna try it once it wams up a bit. It looked like it would go as long as I pulled the upper plenum off the intake.
Old Jan 7, 2005 | 07:23 PM
Mustang 5.0
yep. pull the plenum, attach the hoist as close to the top of the engine as you can. One on the transmission tailshaft, two to pull the hoist forward.
Old Jan 7, 2005 | 08:16 PM
351M's Avatar
351M
I wonder if I can get the hay fork on the tractor in there without damaging anything, I like my '76 Dodge Van, I can pull the engine through the passenger side door.
Old Mar 9, 2020 | 06:33 PM
paul spuria's Avatar
paul spuria
would this procedure work on a 1999 e350 with a diesel? trans out the bottom and engine from the front?
Old Mar 9, 2020 | 08:12 PM
Hank85713's Avatar
Hank85713
search on you tube. There are a couple there on pulling the diesel engines from vans/cutaways should help with some of your questions.
Old Mar 16, 2020 | 12:20 AM
Cubey's Avatar
Cubey
Trailering
One such video:
His webpage on the subject: https://www.nickpisca.com/diesel/tur...econoline-van/
62FE4x4
Mar 28, 2017 02:29 PM
idi1993f350
Feb 1, 2017 03:21 PM
Kef220
Nov 20, 2015 03:28 AM
broford1
16
Jul 28, 2011 05:27 PM
John Such
29
Jul 20, 2011 05:16 PM
