need advice on flexplate retorque
Old Feb 1, 2017 | 09:29 AM
idi1993f350's Avatar
idi1993f350
new engines in my truck, tranny was in and the flexplate came loose. (e4od) can I just unbolt the tranny and jack it up and slide it back on the crossmember to gain access to the flexplate bolts? or do I need to remove the tranny completely again? reason I ask is because I'm working outside in the mud and gravel and its 30 degrees all week so if I can save some time by not removing the t case and crossmember etc. Thanks.
Old Feb 1, 2017 | 03:21 PM
MtTheJeffro's Avatar
MtTheJeffro
I'm not sure you'd have enough room to slide it back with a transfer case still in there. I've done it on a 2wd with a manual trans (shifter removed). Should take too much space although I'd read up on loctite for those bolts this time around.
Devane
1983 - 2012 Ranger & B-Series
Apr 29, 2013 03:45 PM
KenEdwards
Aug 1, 2012 09:08 AM
maldbwmjr
Sep 10, 2008 09:03 PM
runemaster
Apr 29, 2005 03:07 PM
GTStang
Oct 12, 2004 02:49 PM
