Radiator replacement time!
Old Dec 20, 2004 | 09:34 PM
ptt's Avatar
ptt
Vehicle is a 1995 E150 5.8L w/E40D Conversion Van. I've noticed the overflow bottle has been going dry lately. Finally found the radiator is starting to drip on passengers side and leaves a 6 inch puddle after driving it. With the conversion pakage, on this van, it has a transmission cooler in upper right in front of the condensor and radiator. Does it need a special radiator (Say like a manual trans radiator) or does it make no difference with transmission coolant lines that go to a separate cooler. What is a good price for a radiator for this vehicle? Thanks.
Old Dec 21, 2004 | 03:46 AM
nightowl_52's Avatar
nightowl_52
Why replace it ? Take it out and bring it to a radiator shop and have it repaired. Had mine done last summer for $65
While it's out replace the hoses.
Old Dec 21, 2004 | 06:20 AM
Jim1995E150's Avatar
Jim1995E150
I've heard various opinions on reparing (acid rinse, welding leak, etc.) vs replacing, and am not sure which is the way to go. I looked into both when mine went on my E150 several years ago, and the cost to have it removed, acid cleaned, and reinstalled was more than half the cost of having a decent quality new radiator installed. And with a repair job, there is no guarantee it will hold up as long as a new one. If it fails, you will pay labor again.
Now if you can do the labor yourself, it may be worthwhile to give it a go on the repair attemp (all you are out is your time and $60 or so). But if you are paying to do the whole job, I would probably side with replacing it since it is such a critical part to good engine performance and durability, and any decent shop will warranty their work in addition to the warranty that comes with the radiator. In my case, I had some 140,000 miles or so, so I felt that I had gotten my money's worth out of the original radiator.
JE
Old Dec 21, 2004 | 06:21 AM
Jim1995E150
P.S. I want to say my replacement cost between $300 and $400 (labor included), for a Modine radiator. My engine is the 302 without tranny cooler, but I am not sure how much difference it makes in cost.
Old Dec 21, 2004 | 01:44 PM
ptt's Avatar
ptt
Radiator.....
I came across an EBAY unit for $140 shipped but I'm leary. If I have the factory transmission cooler is the replacement radiator of a different design because the cooling lines aren't going to the radiator? Or does it matter? Thanks!
Old Dec 21, 2004 | 02:49 PM
Leo_T's Avatar
Leo_T
I have a 96, and it goes through both the cooler in the radiator, and the aux exterior tranny cooler. Not sure if they all do, or not.
Old Dec 22, 2004 | 04:53 PM
nightowl_52
On my 92 conversion, the trans cooler and radiator lines are in series, in one, out the other. I would be careful buying online, you might end up with a referb instead of new. Amazing what a little paint can do. Pulling that radiator isn't as hard as it looks. I had mine out in less then an hour. The shop reamed out and flushed the rad and fixed a small leak on the top tank and painted it for $65
bossgobbler
Mar 16, 2017 11:56 PM
coolfeet
Nov 21, 2015 07:24 PM
Da_Lariat_Chariot
Oct 16, 2015 07:35 PM
kbarbee95
20
Aug 2, 2015 01:39 PM
dmack
Jun 12, 2002 02:32 PM
