Shutter when taking off
Old Dec 20, 2004 | 09:27 PM
Rizz0's Avatar
Rizz0
Hello,
I have a 77 F150 4x4 400 C6. I have recently had the motor rebuilt along with the tranny. Since I have installed my 6" lift I have noticed this shutter when I take off and even sometimes a clunk. I dont remember it being there before I lifted it but cant say it wasnt there. I didnt really drive the truck much before I lifted it. I recently had the rear driveline extended, replaced the carrier barring and u-joints. The guy from the driveline shop thought it must be coming from the rearend (9") So I took it back down to him and had him pull out the 3rd member and inspect it and everything seemed fine. What else could it be? I really doubt its a tranny issue since it was there before and is still there now. Could it be the transferr case? The guy from the tranny shop wants me to take it to a differnt mechanic then the one that put my motor into my truck and have him check out everything on the motor to make sure its running in tip top shape before he looks at it again. I am going to do this just curious if anyone has any idea what it could be.
Old Dec 20, 2004 | 10:45 PM
rclarke's Avatar
rclarke
Sounds like pinion angle vibration to me. The output shaft from the transmission and the pinion shaft should be very close to parallel. The rear end can be adjusted with tapered caster shims between the spring and spring saddle on the rear end.
Old Dec 20, 2004 | 11:12 PM
Rizz0's Avatar
Rizz0
That is the first thing the guy from the driveline shop thought it was. The blocks I had first put on were tapered. He got another set wich adjust the angle of the driveline and the rearend. I assume this is the same thing you were refferring to. Thanks for the info.
Pool Runner
2009 - 2014 F150
Feb 20, 2014 12:43 PM
sens1fan
2009 - 2014 F150
Dec 4, 2012 01:18 PM
hav24wheel
Apr 5, 2009 09:45 PM
rockstate45
24
Jan 15, 2008 02:06 PM
tsheriff
Nov 11, 2002 05:48 PM
