1994 4WD Ext front differential leak
I took the Dana 28-2 out of my van again. Drained all the fluid. Took out the gears. Sprayed it down with brake cleaner and installed new oil seals. They cost me about $20 CDN for two of them. Before I put it together I will try tomorrow to find a way to install a drain plug in the cover.
I agree that is the best way. I tried a "Speedy Muffler" shop in Burlington on the way to work and they wouldn't do it.
So at work I drilled the hole at the bottom of the cover plate and I found this stuff at work called "LPS Rapid Strong Steel renewal composite" (www.lpslabs.com) to attach a stainless steel nut over the hole. And I am using a rubber o-ring for a seal. And I am using a cut-short stainless steel bolt.
I installed red high-temp silicon gasket to seal the cover back on and it is drying in my basement right now. Silicon says it takes 24 hours to dry.
Will be ready to re-fill my DANA 28-2 with MERCON tonight and re-install into my Aerostar. Then I will be ready for the next snow storm.
"LPS Rapid Strong Steel renewal composite" (www.lpslabs.com). There are two tubes of stuff. One is called a "base" and the other is called an "activator". The website only lists the "strong steel stick" so I am not sure if this is an older product. But I saw some for sale on ebay.
I see. It's probably epoxy just like JB-Weld. Watch that drain periodically, since you don't really know whether that epoxy is compatible with Mercon. When I was a grad student (a lifetime ago ), I used to use epoxy a lot in the experiments I ran for my dissertation, and it was good for most fluid. However, on some fluids (mostly solvents, especially Freon-113), it softened or swelled up over time. So, watch that drain plug from time to time.
housedad
05-30-2014 12:23 PM
Specialtools
Vendor Specials, Discounts, Product Announcements & Group Buys
12-20-2012 10:32 AM
