Sponsored by: Auxito
preventive maintainence for plug blowout?
Old Dec 19, 2004 | 09:01 AM
blueice's Avatar
blueice
Would anyone know if it's possible to install Time Serts into every plug hole to prevent the spark plug blowing out before it happens? Would the plug hole have to be bigger or can you just screw in the insert when you do a tune up? Do the threads have to be stripped in order for the inserts to fit? This may seem stupid to some people but I believe in preventing things as serious as this before something happens. Thanks.
Old Dec 19, 2004 | 10:07 AM
LxMan1's Avatar
LxMan1
I am sure that the hole would have to be enlarged.
If it ain't broke, I wouldn't try to fix it. Most 5.4's never have this problem, for every one that you read about on here, there are thousands of others out there that have no problems. This site represents a small percentage of the trucks out there and most are trouble free.
Old Dec 19, 2004 | 10:48 AM
pjs82's Avatar
pjs82
Time Sert does make a spark plug kit. You will have to drill out and and enlarge the hole because the timesert insert will bring the oversized hole back to original dimensions. Time Fastner's website is www.timesert.com
Check the misc. kits for the spark plug. You have to call for prices (800) 423-4070.
I know nothing about the newer fords so I'm assuming this engine is aluminum? If the hole isn't stripped then leave it be. The best preventative measure you can take is to not overtighten your plugs and don't use anti-sieze on the threads.
Patrick
Old Dec 30, 2004 | 11:12 AM
MarkNelson's Avatar
MarkNelson
The spec for spark plugs requires neverseize according to the dealer. I agree with the comment about overtightening. The bigger problem is that there's only 4 threads to catch, and nearly any level of cross threading will screw you.
Old Dec 30, 2004 | 12:37 PM
superrangerman2002's Avatar
superrangerman2002
Two suggestions:
Rent or invest in a good torque wrench.
Use a high quality anti-seize.
Old Dec 31, 2004 | 10:05 AM
PaulC's Avatar
PaulC
With the hope that it never happens to you, I would wait until if/when it does. I know some members of this forum have inserted HeliCoils/Time Serts into the cylinder heads while still mounted on the engine, but if you're a bit careless and allow aluminum shavings into the cylinder, you risk gouging the cylinder wall and losing compression, power and fuel economy. The least risky method, IMHO, is to pull the cylinder head off the engine, not a pretty task on an overhead cam engine that's a bit buried under the cowl.
Old Dec 31, 2004 | 11:14 AM
Tom's Avatar
Tom
I'm no expert in these things, but IMO it's not a common problem. It has been known to happen, but I believe you have a higher risk of breaking something trying to prevent it than you do of having a truck blow a plug. With over a million of these trucks on the road, sure you're gonna hear of a few problems, but the percentage is very low.
Old Dec 31, 2004 | 11:42 AM
MarkNelson's Avatar
MarkNelson
The fact that Ford re-engineered the head to 10 threads in the sparkplug hole in 2002, up from 4 threads is a pretty clear indication that this is a pretty common problem. My dealer here sees 1 blown plug a week with a $3500+ fix.
Old Dec 31, 2004 | 02:45 PM
fifteen+'s Avatar
fifteen+
we have been taking the plugs out at 50 000 km and re-gapping and installing anti-sieze on threads.this did reduce the problem.
Old Dec 31, 2004 | 03:46 PM
blueice's Avatar
blueice
Thanks to everyone who replied. I guess sometimes I worry for nothing.
