2.9 getting codes 19 and 33 from continuous memory test
Old Dec 19, 2004 | 12:21 AM
91ford_ranger's Avatar
91ford_ranger
Pulled codes from 1986 2.9 and got codes 19 and 33. Truck driveability symptoms are hard starting when hot and "hiccup on decel.
Any thoughts or comments appreciated.
Old Dec 19, 2004 | 03:07 PM
danger_ranger_dude's Avatar
danger_ranger_dude
might want to check the timing or your Oxygen sensor.
Old Dec 19, 2004 | 07:57 PM
91ford_ranger
Thanks, will check into that next
Old Dec 19, 2004 | 08:25 PM
Ken00's Avatar
Ken00
The 19 is a problem with power to you ECU and the 33 is an EGR code, you should run the pinpoint test for both codes before replacing anything. Drop me an email if you need them.
danboy282
Bronco II
Feb 29, 2012 06:35 PM
danboy282
Bronco II
Jan 30, 2012 10:21 AM
NitrousAl
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Apr 15, 2005 05:50 PM
Bill864x4
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 2, 2004 05:31 PM
shanejackson
1997 - 2003 F150
Mar 28, 2004 11:53 AM
