Brake pedal height
Old Dec 19, 2004 | 12:17 AM
Cheapevil's Avatar
Cheapevil
Brake pedal height
I've got a 76 f250 4x4 crew cab, was wanting to know if the brake pedal sits way high in all of these trucks 73-79 or is there a way to adjust the height. Mine sits so high that I have to lift my foot up off the gas to step on the brake, can't just slide it over. hope I have explained this well enough(since I can't draw a picture) to get some responce. Thanx for any help.
Old Dec 22, 2004 | 11:41 PM
Cheapevil's Avatar
Cheapevil
What up 25 reads and no replies, come on someone please help me out here. How about some pics of some interiors showing the pedals atleast.
Old Dec 22, 2004 | 11:50 PM
oldhalftons's Avatar
oldhalftons
it should sit pretty high.
This is how they should sit when everything is perfect.
The Brake pedal will slowly drop as the master and booster go bad.
Old Dec 23, 2004 | 11:16 AM
73Custom's Avatar
73Custom
Do you have power brakes or manual brakes?
My '73 F100 came with manual brakes, and I had to raise my foot to get on the brake pedal - it was even with the clutch pedal. A couple years ago, I installed power brakes and now the pedal is more even with the gas pedal - much more cofortable for driving.
Marty
Old Dec 23, 2004 | 02:07 PM
olfordsnstone's Avatar
olfordsnstone
Oldhalftons, thats a stock AM radio eh? Nice. I would go original too but need to listen to my old country music with some definition.
Cheapevil, I think I need to lift my foot a little but not exessively high. I'll check when I get home from work the day after tomorrow. The power vs manual brake thought is a good one too.
I know that there is an adjustment in the shaft between the master cyl and the pedal but I don't think that would make a difference in where the pedal sits. Unsure though as I cant see it from here. (I converted to a 76 brake system in my 74 for the discs brakes) I'll check the day after tomorrow
Old Dec 23, 2004 | 07:29 PM
oldhalftons
the truck has power brakes and the brake sts higher then the gas but lower then the clutch.
Yeah its still got the old AM radio
Old Dec 23, 2004 | 10:46 PM
ford390gashog's Avatar
ford390gashog
why not just adjust the gas pedal to the same heaight as the brake
ol-blu
Nov 6, 2024 08:05 AM
dinikin
1997 - 2003 F150
Dec 15, 2009 06:23 PM
carcrafter22
Jul 9, 2008 05:01 PM
DrkPhanstm
Apr 29, 2002 01:24 AM
