302 Radiator
Old Dec 18, 2004 | 08:01 PM
DT 466Man's Avatar
DT 466Man
302 Radiator
Well i fixed my carb and i fixed my transfercase. School let out for the winter so i started fixing up my truck. Well i got back from a little test drive and i looked under the hood to check for leaks and guess what? Coolant is driping off the radiator GREAT. Whats next. The good news is i get a free 80000 mile 302HO and AOD trans out of my friends Lincoln DemoDerby Car That he never finished. I was wondering being the stingy teenager i am would the 302 radiator fit inplace of my 300's?
Old Dec 18, 2004 | 08:35 PM
DT 466Man's Avatar
DT 466Man
Any one know?
Old Dec 19, 2004 | 09:37 AM
Flareside_4x4's Avatar
Flareside_4x4
the inlet/outlet are on opposite sides from a 300 to 302.
Old Dec 19, 2004 | 11:49 AM
fordinlinesix's Avatar
fordinlinesix
What Flareside said, you can reroute the hose using different ones though.
Old Dec 19, 2004 | 04:59 PM
DT 466Man's Avatar
DT 466Man
my radiator looks like it is leaking where the tank meets the core and i was quoted 30 bucks to fix it
I might just have it fixed
It is leaking on the driver side under the inlet and it goes all the way down the side of the tank where it meets the core.
Any one ever have this happen?
Old Dec 19, 2004 | 05:40 PM
fordinlinesix
Yeah, it happens to many people. It just seperates from stress or whatever.
Old Dec 19, 2004 | 06:53 PM
DT 466Man's Avatar
DT 466Man
so it is a common problem on older trucks?
So a repertable shop should know exactly how to fix it right?
I might try to talk him down to 20 -25 bucks
Old Dec 20, 2004 | 02:14 PM
DT 466Man's Avatar
DT 466Man
Ok i'm gettin that fixed today and i will have it back by tommorrow morning
I replaced the thermostat and guess what it was the ORIGINAL thermo
Was i correct in putting the part with the spring towards the head?
Old Dec 20, 2004 | 02:27 PM
DT 466Man's Avatar
DT 466Man
oh and my truck has a half fan shround like it has been cut off how much will that affect the cooling?
Whats the proper way to flush and put in new coolant with out getting an air pocket?
Old Dec 20, 2004 | 03:02 PM
fordinlinesix
It's common on newer vehicles too, it's just something that happens like water pump failure or anything else like that. I probably wouldn't worry about it happening again. They should know how to fix it. Dunno about the fan shroud, mine didn't come with one. Probably better than nothing though. I pour coolant in until the radiator is full, then squeeze the upper radiator hose several times slowly and it will push water into the head, just keep doing that until it's full. And with the thermostat, yes you put it in right.
Old Dec 20, 2004 | 04:09 PM
DT 466Man's Avatar
DT 466Man
Alright thanks
i'm still supprised it was the original thermo
