Sponsored by: Auxito
Code reader question
Old Dec 18, 2004 | 09:37 AM
northsea's Avatar
northsea
Is there an inexpensive code reader that will work for the 99 F150 4.6L auto?
Northsea
Old Dec 18, 2004 | 07:44 PM
Racerguy's Avatar
Racerguy
Any OBD2 (On Board Diagnostics generation 2) code reader should work. Most vehicles after 1995 are OBD2.
If your check engine light is on and you want to get it scanned some parts stores like Autozone will do that for you for free.
Old Dec 18, 2004 | 08:09 PM
15098's Avatar
15098
http://www.harborfreight.com/
input item # 46030-1VGA
Old Dec 18, 2004 | 09:23 PM
F150'89's Avatar
F150'89
AutoZone sells one for $79.99
Old Dec 19, 2004 | 08:17 AM
northsea's Avatar
northsea
Thanks OBDII another question is there one for a 1992
I also need one for a 92 sable. Would this same OBDII work on this or is there another?
Northsea
Old Dec 19, 2004 | 08:53 AM
F150'89's Avatar
F150'89
ODBII will not work on your Sable, there is a code scanner for older Fords and it sells for about $30.00
Old Dec 19, 2004 | 12:18 PM
northsea's Avatar
northsea
Thanks for all the help.
Northsea
Old Dec 25, 2004 | 08:50 AM
northsea's Avatar
northsea
Code reader
Where does the code reader plug in?
Northsea
Old Dec 25, 2004 | 02:21 PM
F150'89's Avatar
F150'89
Northsea
Drivers side under the dash
