98 5.4 - Insert, Replace Head, or Engine
Old Dec 17, 2004 | 04:50 PM
lospinoj's Avatar
lospinoj
Now that it's official, #3 plug launched and took the thread with it. I'm faced with some choices:
1. 4900 installation of a rebuilt engine (3 year \ 36,000 mile warranty)
2. 2500 passenger side head replacement (1 year \ 12,000 mile warranty)
3. 400 & a few busted knuckles for the insert, which hopefully can be done without removing the head.
What I'm wondering is if I'm ultimately just going to pop another one and be back to square one.
I would almost go for the head replacement if I could be sure that the replacement head isn't as defective as the one there putting on.
Is it mostly the right side that is prone to this defect, if not, maybe I should just clinch my teeth and go for the factory rebuilt engine.
Would I stand a chance at doing the insert on my own, I'm handier than most, can do breaks and other light repairs, but have not tackled anything like removing a cylinder head.
Any help would be greatly appreciated.
Oh and if there are any other victims of this problem, according to the (4) ford dealers that I spoke to today and the customer realations center, I'm the first one to ever report this problem........ha.
Jeff
Old Dec 17, 2004 | 05:00 PM
buzzard's Avatar
buzzard
Bad luck as well as bad timing with the holidays.
Personally, I'd go the insert route. There are a couple options, so I'd suggest doing some research. Since this is a common problem, you will find tons of info on this and other Ford truck websites.
Old Dec 17, 2004 | 07:33 PM
chefbob's Avatar
chefbob
Same thing happen to my 98 5.4 back in August, #3 plug blew out. Tried the insert route first....did'nt work, had to replace the head. Runs like a new truck now, lucky I had bought a month earlier and it was covered under warranty from the Ford dealer. The invoice had a quoted price of $2300.
From what I understand the insert is a temporary fix due to soft aluminum heads.
Old Dec 17, 2004 | 10:23 PM
gkbid's Avatar
gkbid
Two weeks ago my 99' 5.4 launched a plug while my wife was driving. I didn't know which cylinder had let go, yet on the way home to check it out I stopped at NAPA and picked up an insert kit for $40. I figured I could probably get to 6 of the 8 spark plug bores (with the heads installed), so I figured I had about 75% odds that I could repair it. The bad news was it was number 4. The blown plug trashed the COP but fortunately it didn't take out the threads in the head. I was lucky, but felt I would have had nothing to loose by trying to repair it with the insert... and had several thousand to possibly save!
My suggestion is to pick up an insert kit and give it a try... you're not gonna hurt the plug bore any more than it already is... and if all goes well will save major bucks. You'll find there are quite a few threads about blowouts having been repaired successfully with inserts!
Good Luck
Old Dec 18, 2004 | 11:50 AM
78Explorer's Avatar
78Explorer
I feel for ya'...My 98 Expy is still sittin' in my garage with a fist-sized hole in the right side of the block near the oil pan (number 2 or 3 cylinder launched a piston/connecting rod through it). I've got my local ford dealer down to $2840.00 for a new reman 5.4 with 3 year/36 month warranty. Still trying to decide which route to take. There's a 5.4 on ebay complete (wiring harness, intake, injectors, rails everything) and NOT rebuilt - it's ALL brand new with 0 miles on it for $2895...the clincher is it has NO warranty...don't think I want to drop that kind of dough for something "sold as is".
What do y'all think?
Old Dec 18, 2004 | 02:40 PM
gkbid's Avatar
gkbid
If it were me I'd go with the 3 year/36,000 mile warranty... just my 2 cents worth.
Old Dec 18, 2004 | 03:09 PM
78Explorer's Avatar
78Explorer
Yep...that's my thought too..I can always take the externals from my engine since they're not hurt - that warranty is worth ALOT of peace of mind. They want $1100 to install it. I may let them do that too...the jury is still out on that one.
Old Dec 18, 2004 | 03:45 PM
Monsta's Avatar
Monsta
Sit. Stay.
www.timesert.com
The insert is not a temporary solution. It is in fact the solution. If all the sparkplug holes had inserts we wouldn't be having this conversation.
Old Dec 21, 2004 | 07:16 AM
lospinoj's Avatar
lospinoj
Thanks All
After weighing out all my options, one of which is to not attempt the insert repair on my own, I'm going for the head replacement at the dealer with the 12\12000 warranty.
If I did go the insert route, with the amount of labor that I have to pay out just to get to the #3 hole I'd be inclined to de em all, which adds up to I might as well get the whole thing replaced a warranteed. If I did do just one and another was to blow, the level of I told you so's from the home boss would kill me.
I did ask the good people at Ford if the replacement head will have the same defective design, as much as I beat em up, I could not get them to fess up.
Does anyone know if they beefed up the threads in the replacement heads ?
Replacing the engine sounds nice too, but I'm not feeling all that confident if Ford these days, how well was it rebuilt, was it rebuilt with the defective heads ?
The next step will be to sell it off and buy a Toyota, I hate to do it, but they just don't break like this.
Old Dec 27, 2004 | 08:53 AM
lospinoj's Avatar
lospinoj
As my truck sat for a week at the dealer awaiting a replacement head, I decided to pull it out of there and give the insert a try. I understand that I have the option to first use the "thin wall insert", then fall back on the "bigsert" if I have to, but timesert seems to recommend using the bigsert the first time around. I'd like to just do this once.
Does anyone have any recommendations on the best coarse to take here ?
Also, the proper part number for the bigsert kit and insert appears to be 5551 and 51459, as shown on timeserts web site.
Thanks All.
Old Jan 4, 2005 | 07:45 AM
lospinoj's Avatar
lospinoj
Thanks all for your expert advice.
I managed to get the insert installed on Friday and the truck is back on the friendly roads of Northern New Jersey.
Old Jan 4, 2005 | 06:32 PM
gkbid's Avatar
gkbid
Originally Posted by lospinoj
I managed to get the insert installed and the truck is back on the road.
Congratulations! Glad to hear you're back up and running
Old Jan 4, 2005 | 09:48 PM
PhotoJoe's Avatar
PhotoJoe
How bad?
How tough was the job? have to pull the motor, head, or just do it in the truck? How long did it take?
Thanks, just planning ahead for when....uh.....if I have to do it!
Old Jan 5, 2005 | 06:04 AM
lospinoj's Avatar
lospinoj
I was able to do it on the truck. I moved the wiring block aside, diconnected the heater hoses, and moved aside a few other smaller vacum lines (after lableing everything). The TimeSert kit certainly works as advertised, but I was not able to use the T Bar handle and instead had to use a socket a ratchet on top of the tool holder.
With my modest skills, it took me about 6 hours (3 actual work, 3 head scratching). I suspect a seasoned mechanic could bang this out in a few hours.
By the way, I've run across numerous thread were folks have done the #3 hole on the truck, and I'm sure I even read one where a guy did the #4.
