Dead battery again???
Old Dec 17, 2004 | 03:47 PM
glenn150's Avatar
glenn150
My '93 F150 V-8 has a new dead battery (engine won't turn over, but electrical devices are ok).
Noted battery was not looking like it was not recharging on its one week with me.
Have it on a charger now but its sounds like it could be starter? or alternator? or ??
I am far out of the city ad want to try to diagnose before getting parts or towing to a shop.
Thanks,
glenn
Old Dec 17, 2004 | 04:34 PM
andym's Avatar
andym
Starting problems are actually pretty easy to diagnose. With a fully charged battery, the engine should crank over. If it doesn't, try shorting the terminals on the starter relay on the passenger's fenderwell. If it cranks over and starts, then it's either the starter relay itself or the ignition switch in the column. If it still won't crank or cranks but sounds weak and won't start, it's either the battery cables themselves or the starter.
Charging problems are different, and are usually either a worn out alternator or dying battery. Best bet there is to take both to a parts store and have them tested.
Old Dec 18, 2004 | 06:47 AM
mattskn's Avatar
mattskn
Had a similar problem with my 95 f150! had new battery,starter,alt ended up being the starter not being grounded out. there was oil between the starter and bellhouseing cleaned it and ran a ground from the starter to frame took care of the problem.hope this helps also had same problem with 88 f250
Old Dec 18, 2004 | 10:01 AM
tex94F250's Avatar
tex94F250
If that doesn't work check your ground cable from firewall to engine block (or bracket attached to block). If it is loose, it will not start. If you can jump the solenoid though, that's where I'd start with parts. Checking cables and cleaning connections is still free.
Tex
94 F250 460 cid E4OD 4x4
GLaJudice
May 7, 2014 02:10 PM
glenn atkinson
Feb 3, 2014 07:35 PM
Glenn0184
1983 - 2012 Ranger & B-Series
Apr 21, 2002 11:36 PM
xp8103
Apr 10, 2002 08:56 PM
glenn 79
Mar 28, 2001 02:10 PM
