Cutting access hole in cab?
Old Dec 17, 2004 | 03:31 PM
mzimmers's Avatar
mzimmers
Hi, all –
I'm starting to explore the possible routes for running electrical wires (power, speaker, interconnect, etc) between the truck cab and the bed. Does anyone have any suggestions for entering the cab? I'm thinking of coming in near the bottom-middle of the back, but I'm not sure what the best route into the bed is. This is for a 2001 F-150 SCrew.
Thanks...
Old Dec 17, 2004 | 09:39 PM
Rosati's Avatar
Rosati
Usually you can install power wires along the OEM harness up to the firewall and utilize an existing grommeted hole to pass the wires through. But if your doing a complete custom job (amps, extra batteries and such) I would suggest drilling your own holes and be shure to check bith sides of the firewall for wiring and such before drilling. You can usually find rubber grommets at auto supply stores or radio shack.
If your installing things in the bed of the truck, I'd suggest going through the floor of the bed, along the frame , then up into the cab. This way the bed and cab can still flex without damage to the wiring.
99hosss
Jul 31, 2011 10:14 AM
transam525
May 10, 2010 02:48 PM
Nightrain
Exhaust Systems
17
Mar 8, 2007 10:34 AM
tri 5 ernie
May 12, 2004 06:02 PM
jbradley
May 25, 2002 10:17 PM
