302 intake interchangeability
Old Dec 16, 2004 | 07:58 PM
phat56's Avatar
phat56
Does anybody know if the intake from a '86 302 will fit on a '68 302 - both normally aspirated ?? I think they are the same, but I want to be sure before going through a bunch of shipping headaches to find some subtle difference.
Old Dec 17, 2004 | 08:04 AM
312's Avatar
312
they all fit.
Old Dec 17, 2004 | 09:31 AM
EPNCSU2006's Avatar
EPNCSU2006
Is the '86 EFI? It'll fit, but I just don't want you to buy an EFI manifold expecting to get one for a carburetor.
Old Dec 17, 2004 | 11:29 AM
phat56's Avatar
phat56
They're both carb'd models. After doing more research, I am covinced they are interchangable. thanks guys
Old Dec 19, 2004 | 11:12 PM
the ranger's Avatar
the ranger
Talking they all do...
no problem there, i got a 68 302[ # 38 off the line ] i also have a 80 302, and also a 86 302. and i've taken parts from all these engines and built one engine for my ranger. and all the intakes interchange. all 3 engines were all original stock engines. so your safe there.the rangers engine runs great!!! she has a 68 302 with a 86 2barrel intake. with a holley 600 2 barrel. thump, thump, thump, thump,thump,thump,thump,thump. V-8 rangers rule the road!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! The Ranger...
Old Dec 20, 2004 | 05:50 PM
phat56's Avatar
phat56
well then- I guess that clinches it. It's on the way Thanks again
Old Dec 20, 2004 | 09:02 PM
the ranger's Avatar
the ranger
one other thing!!!
there is one thing you need to make sure you do.make sure you get the right spacer plate for it. the spacer from the 68 will not work on the 86. it will slide on the studs, but there will be overhang because the manifold base is offset a little. and the spacer on the 86 works fine for the 86 manifold , but it has a built on egr valve.and i don't know how you are running your pcv system, but you will have to take that into consideration when doing the carb work. im using the 68 spacer on the 86 manifold. i found a way around the problem. but let me know what you decide to do, i will help you along... The Ranger.....
Old Dec 20, 2004 | 09:08 PM
phat56's Avatar
phat56
Thanks Ranger - It seems like a relatively small problem, many of which have been beaten down. Victory shall be mine, of this I can assure you.
Old Dec 20, 2004 | 09:15 PM
the ranger's Avatar
the ranger
right on !!!
no problem man!!! yeah, it is a small problem, that will drive you nut's!!!!!!!!if you did'nt know about it, but now you know , so no problem... good luck and let us know how she goes......................................
Old Dec 21, 2004 | 11:34 PM
matt17's Avatar
matt17
when i carbed a 86 roller 302 i used a 2- barrel intake of a 255!
Old Dec 27, 2004 | 02:45 PM
ClatonK's Avatar
ClatonK
I was going to do a simular swap but after doing some looking (comparing 1969 and 1983 Ford 302 intakes), the newer 302 intakes have larger water ports and a rear water crossover. The 83 also seems to have slightly smaller intake ports. Also, the guy at the parts store says the two years take differnt intake gaskets.
I think the swap will work but the ports will be differnt sizes and this may hurt air flow. I would think that you should also get the gasket to match the year of the intake.
Anyone else have any suggetions for this?
Clayton
Old Dec 28, 2004 | 09:04 PM
phat56's Avatar
phat56
I think port matching with aluminum isn't too tough, and I believe the water passages should only help with cooling ??
captain1997
Sep 16, 2014 05:59 AM
Raxid
Jun 20, 2009 08:29 AM
joewaldner
34
Jul 17, 2007 02:13 PM
