When to have first service?
Old Dec 16, 2004 | 10:48 AM
ISUPhiPsi1052's Avatar
ISUPhiPsi1052
2005 SCAB-XLT.
Should I wait until I hit 3,000 miles for my first oil change/tire rotation? Sorry far no problems with the vehicle - I love it!!!
Old Dec 16, 2004 | 12:25 PM
mike8150's Avatar
mike8150
Oil change
I just changed my oil at 5,000 like the manual said. These trucks only use synethic oil. I have a 2004 f150 xl. My oil was still very clean after 5,000. Changeing every 3,000 is a waste of money with synethic oil. Not to mention that if you took it to a place to get your oil changed it would be $50-$60. It cost me $18 to do it myself.
Old Dec 16, 2004 | 12:27 PM
jbigdog's Avatar
jbigdog
First Service
BTW,
Walmart has the Ford recommended oil and filter. Oil was $1.45 a quart. I did mine at 5K miles also.
jdb
Old Dec 16, 2004 | 03:45 PM
stl1's Avatar
stl1
I will also wait for the 5k service. If you run your truck hard, pulling trailers etc, you may want to service before 5k.
Old Dec 16, 2004 | 04:01 PM
Monsta's Avatar
Monsta
Sit. Stay.
My truck has 2300 miles and is on its 3rd "set" of oil.
Motor oil is cheap. First change was 1000miles. (dealership ((not Ford)) I bought it from put in 10W-30 & a Fram. ) At 1300 I switched back to 5W-20 MC.
I don't know...I'd change at 3K and again at 5K. Just me, though...
Old Dec 16, 2004 | 07:19 PM
Flash's Avatar
Flash
I would suggest changing oil somewhere around the 1500 mile mark. The engine is new and will use some of the additive package in the oil to "plate up" the engine. The engine can suffer from additve depletion which can accelerate wear. The most "break-in" wear is in the first 1500 so it is a good idea to get rid of the fine metal pieces. The engine is also going to have junk in it from the manfacturing process that is floating around in the first oil that it sees so it is a good idea to change the first time early. Then go to a 5000 mile OCI. Your engine requires a 153-H or 929 rated oil, the oils are designed to go the distance with no problems and are a synthetic blend at minimum.
Old Dec 17, 2004 | 06:31 AM
ISUPhiPsi1052
Thanks all. Great information. I'll schedule my first service call after the holidays...
Old Dec 17, 2004 | 07:18 AM
Aftrmidnite's Avatar
Aftrmidnite
First oil change at 1000 miles, second at 3000, third at 5000 miles at 10,000 miles I switched to a full synthetic. Used 303 early on on all the interior plastic, and soaked the rubber weatherstripping with 303. Lubed the locks early on, and pulled all the wheels and never seized the studs. If its a 4wd, might want to pull the discs and use a light coating of never seize on the mating surface. My caliper slides had no caliper grease on them, so I took care of that. Greatly reduced the brake dust. If it sat on the lot for awhile good idea to run some "dry gas" thru the tank. Also I usually replace wiper inserts early on as the OEM ones are usually pretty bad. There is a maintenance manually in your owners pouch, I would get in the habit of doing the service and checking it off.
Old Dec 17, 2004 | 08:07 AM
jcherman's Avatar
jcherman
My own oil change?
The dealer i bought my 04 scab from implied that changing my own oil may affect my warranty. I don't really believe him but Im conserned all the same. I have never paid for an oil change so am not excited about starting now. Should I worry about this? Also, I have read here that I should be using synthetic oil but I don't believe that this is what is in the truck now. I only have 1500 miles so now is the time to convert if it's the best idea. What do you guys think?
Old Dec 17, 2004 | 08:33 AM
Aftrmidnite
I'm not an expert on oil type verses engine wear in, but I was told to use regular oil at first to wear in the rings, and other parts. I've always put a lot of miles on a vehicle before junking it and have never had engine problems, except for a Datsun 1200, that was rebuilt at 180K and a Dodge Mitsubusi Challenger that had bad valve "O" rings that were replaced at over 100K. Your dealer is full of it, about the oil changes, if you are worried keep your receipts. As long as you are keeping to the maintainence schedule they can't say much.
Old Dec 17, 2004 | 08:37 AM
KevinM's Avatar
KevinM
Ford spec is limited to a few oils, with more getting on board. Motorcraft synthetic blend 5W-20 has the WSS-M2C153-H spec and is the oil used by Ford. It's $1.42 qt.. Can't see how changing your own oil will void warranty, just keep the receipts for the purchased oil and filter, and document it's mileage. Change it per the owners manual.
If you read the owners manual the first oil change is not needed until 5,000 miles. Dealerships say elsewise and shorten this to get the revenue.
Southpaw1
Jan 14, 2014 10:40 PM
MW95F250
Ford vs The Competition
136
Dec 1, 2007 05:26 AM
kameronth
Dec 25, 2004 02:57 PM
alfama351
May 19, 2004 06:41 PM
Thomsen
15
Feb 19, 2004 12:22 AM
