First Truck
Old Jan 14, 2014 | 01:25 PM
Southpaw1's Avatar
Southpaw1
First Truck
I was wondering if the sport trac would make a good first truck and if not, what would.
Old Jan 14, 2014 | 01:53 PM
Killgore's Avatar
Killgore
Depends on your definition of "truck". I would be iffy about loading it up any heavier than I would load a ranger
Old Jan 14, 2014 | 02:02 PM
Southpaw1's Avatar
Southpaw1
Well I should say sport utility truck. Would it be good for modifying and offroading. Because I wanted to do a lift kit and bigger wheels and tires
Old Jan 14, 2014 | 02:37 PM
85e150's Avatar
85e150
The IFS with torsion bars is not easy to fiddle with. Add to that the rollover history and roof strength issues, and lift makers shied away from the Explorer in any and all configurations. However, there are ways to get 1 1/2 to 2" with just a torsion bar twist, and you can raise the back fairly easily. Body lifts are also available, as are some lifts for the front.
If it exists, you will find it, or find out how to make it, here:
http://www.explorerforum.com/forums/...play.php?f=135
From that site, a Sport Trac story:
http://www.explorerforum.com/forums/...threadid=95827
Old Jan 14, 2014 | 04:51 PM
Southpaw1's Avatar
Southpaw1
what would you recommend for offroading that can be lifted and modified that is different
Old Jan 14, 2014 | 05:33 PM
Killgore's Avatar
Killgore
Well there are rangers and f150's. If this is also your daily driver, and you arent going to need to haul anything heavy, rangers will probably net you better mpg and lower insurance. They are also shorter and are better for rock crawling in that sense. Now if you want to upgrade this truck to be a beast later on, I would say go f150 or 250
Old Jan 14, 2014 | 10:40 PM
85e150's Avatar
85e150
Did you see the dudes Sport Trac on that other forum? Is that not enough?
If not, you probably need to move up to the F150 or similar.
ctubutis
Aug 13, 2014 12:35 AM
68 351 bronc
Nov 25, 2004 09:27 PM
03ST
Jun 23, 2003 08:58 PM
fords_built_tough
May 20, 2002 06:31 AM
