Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Flare nut wrenches
Old Dec 17, 2004 | 09:00 AM
RR4E's Avatar
RR4E
I may say, if they don't fit quite right, perchance you need metric vs standard, or the other way around. Both are close, but neither are correct for the other application. Flar nut wrenches don't spread by design, and if they simply do not fit, or are rounding off nuts, you're using the wrong one. Grab the opposite set from what you have. Metric vs standard, that is.
Old Dec 17, 2004 | 10:57 AM
GLR's Avatar
GLR
I have both Snap-on and Craftsman SAE but use Snap-on the most,the fit is better. For metric I have a Mac set that works great.
Old Dec 17, 2004 | 11:34 AM
patsplace's Avatar
patsplace
S-K are a lot cheaper... about $51 from thetoolwarehouse.com.... anyone have any experience with these?
I've had a fair bit of expreience with SK and I think that they're right up there with the best of tools. Getting warrenty is more difficult though. Snap-on has the trucks and Sears has the stores.
Pat
Old Dec 19, 2004 | 11:04 PM
midlf's Avatar
midlf
OK - I'll ask another question on this line. Are the flare nuts on '93 Ford trucks metric or SAE?
My past, poor, experiences with Craftsman flare nut wrenches was with SAE fittings. I know they were SAE as there were no metric sizes at all on the vehicles I worked on. I will not cut Craftsman any slack because most of the tube nuts I worked on were somewhat rusty. I recently needed to use them on a water hydrant packing nut, absolutely no rust, and they were as inadequate there as on any automotive fitting.
Old Dec 19, 2004 | 11:54 PM
titanicf150's Avatar
titanicf150
The worse the condition of the flare nut or especially the water hydrant packing nut ( 3/4" & made of brass) the more the need for a snap- on FN wrench. when they are rusty try tightening them just a smigen before you try to break them loose. Granted Snap on wrenches are prohibitivley expensive, some stuff just works where others dont
Old Dec 20, 2004 | 12:26 AM
Hangfire's Avatar
Hangfire
Okay, if not Craftsman, who make a moderately priced FN wrench that works???
Old Dec 20, 2004 | 12:36 AM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
My Husky flare nut wrenches seem to work okay. They haven't slipped, stripped, or spread. I use them maybe 2 or 3 times a year though, so my opinion is pretty much worthless.
Old Dec 25, 2004 | 02:38 PM
Rogue427's Avatar
Rogue427
Snap On
I have the snap on FN wrenches aand they work very good. Buying the craftsmans is a waste of $. Using a craftsman on a FN is a waste of time. IMO. Most of my tools are craftsman and some snap on. Tim R.
Old Dec 26, 2004 | 06:58 PM
Torque1st's Avatar
Torque1st
Posting Legend
The Craftsman wrenches I have "fit" the SAE flare nuts fairly well. The steel they are made from just has the wrong heat treatment and they lack the strength to hold the nut without spreading and losing their grip when torque is applied. They are just defective. Heat treatment seems to be one of the places that "cheap tool" makers cut corners. It is also one of the more difficult parts of the manufacturing process.
Bigrigfixer says his Husky wrenches work and they should not be expensive. Another user has had Craftsman FN wrenches that worked and two more have not. Other users liked their Proto wrenches.
Old Dec 27, 2004 | 09:18 AM
pfogle's Avatar
pfogle
We have MAC line wrenches, in both SAE and METRIC. I can tell you now we've not found a better set.
Old Dec 27, 2004 | 09:29 AM
Howdy's Avatar
Howdy
I've found with FN fittings, (or any nut for that matter), if I tap the wrench with my hammer it'll break loose easier than just pulling it. Sometimes just the impact of slapping it with my hand does the trick. I haven't rounded one off in years, but then we don't have the rust problem I've seen in other parts of the country.
Old Dec 27, 2004 | 11:47 AM
Aftrmidnite's Avatar
Aftrmidnite
I checked my set after I found them. They are K/D with the odd sizes filled in with Craftsman, noticed that the heads are thicker than standard wrenches. I know Craftsman at the time was cast by Singer sewing machines. Never had in problem with them, and I was using them in the Midwest. Bought them round thirty years ago, not to show my age, think I was four or five when I bought them
Old Dec 30, 2004 | 10:38 PM
  #28
Bart99GT's Avatar
Bart99GT
I too have found the older Craftsman tools, even ones from 10 years ago, are of better quality than what is being passed off now. I recently bought a 1/2 drive u-joint, and the fit on the male end is so-so at best. With some sockets it doesn't even completely seat itself. Oh well, I still beat the crap out of them because I know if I break one, a replacement is only a short drive away. I shattered two 1/2" drive breaker bars in the same day and the guy at the counter didn't even flinch...nor did the damn hub nut I was trying to break loose either! (It later required a impact gun rated to 650 lb/ft to break it loose...spec on this thing was 180 lb/ft, gotta love it when someone breaks out the heavy duty impact to replace a damn CV joint)
I had an older Craftsman 3/8" drive ratchet, but sadly it stripped out after who knows how long. At least the store where I traded it out at was out of the standard ratchets and I got one of the more stylish "pro" ratchets in its place.
Old Jan 1, 2005 | 06:39 PM
  #29
skmodmsl's Avatar
skmodmsl
I have a set of Craftsman flare-nut wrenches and yet to have a problem with them. I also have Matco and Snap-On FN wrenches. SK and Husky are pretty good and reasonable.
Old Jan 1, 2005 | 08:28 PM
  #30
Fair 96's Avatar
Fair 96
I got snap on and would buy them again they work the best for sure.......
