Offroad & 4x4
loose U-joint
Old Dec 27, 2004 | 05:44 PM
  #31
Psyte's Avatar
Psyte
alright, well i took the sockets back and the guy finaly found me one with 4 notches and it fit. so now i have most of it appart and the only thing keeping me from getting the axel out is the spindle wich seems to be totaly fused on. there was about 8 bolts holding it on but after removeing them it doesnt budge. any tips on how to remove this?
Old Dec 27, 2004 | 05:52 PM
  #32
Ryan50hrl's Avatar
Ryan50hrl
yoru in luck...all kinds of ideas on how to get it off in this thread...
http://www.fordtrucks.com/forums/sho...d.php?t=323383
Old Dec 27, 2004 | 09:50 PM
  #33
Psyte's Avatar
Psyte
alright, i got the spindle off. the axel seems to be equaly as tough though. any tips on how i get that out?
Old Dec 27, 2004 | 11:05 PM
  #34
Ryan50hrl's Avatar
Ryan50hrl
The axle as in you can't pull the shaft out of the housing??? Cause that ought to just pull right out...nothing holdin that in.
Old Dec 27, 2004 | 11:15 PM
  #35
monsterbaby's Avatar
monsterbaby
my guess is you are just having trouble getting it through the knuckle it is a very tight fight, and you need to have the wheels pointed straight, then wiggle it through, but like I said it fits through snuggly
Old Dec 28, 2004 | 12:56 PM
  #36
gatesj's Avatar
gatesj
Originally Posted by ivanribic
I think he's talking about the socket for removing the hub nut, not the sockets he's using to press the U-joints out. How many notches does your hub nut have? Some are 4 and some are 6. It's not a very good fit even if you have the right socket but once you break them loose they'll come right out.
You're right. Strange, the first thing I see is monsterbaby replying.
Old Dec 28, 2004 | 02:07 PM
  #37
Psyte's Avatar
Psyte
i meant i cant seem to pull the axel out of the differential
Old Dec 28, 2004 | 02:41 PM
  #38
monsterbaby
what is strange about that?
Old Dec 28, 2004 | 02:50 PM
  #39
gatesj's Avatar
gatesj
Nevermind me, I pulled a dumbsh** thing, I came in on the second page. No wonder I didn't understand the discussion.
Actually, RubberDuck gave a really good breakdown, nice, I have to do this fairly soon..
Old Dec 28, 2004 | 04:12 PM
  #40
Psyte's Avatar
Psyte
so.... any tips on removeing the axel from the differential? or should it just slide out nicely? am i suppost to seperate it before the differential somewhere?
Old Dec 28, 2004 | 04:19 PM
  #41
monsterbaby
If you are talking the passenger side then yes there is a slip joint in the axle look at the axle from the back side, and you will see a rubber boot with 2 clamps on it remove one of the clamps (you will have to cut it off as they are a crimped type of deal I just replace them with a hose clamp), and the axle should seperate right there with a splined slip joint, if you need to get the inner part of the axle out to replace that ujoint, you will need to drop the pumpkin out as the pass side on the TTB frontends is held in with a C clip
zxwut?
34
Sep 23, 2024 10:08 PM
sowaxeman
May 31, 2015 02:28 PM
danlyst13
Jan 31, 2015 10:58 PM
mich800
6.4L Power Stroke Diesel
15
Aug 22, 2014 07:45 AM
CG-Lock Racer
Jan 31, 2013 09:46 PM
