Looking at a 01
Old Dec 15, 2004 | 11:39 PM
monkeychops's Avatar
monkeychops
Question Looking at a 01
Hey guys,
I did a search on this and it didin't yield anything substantial.
I'm looking at getting a 2001 s/c 4x4 with at 4.0 in the next month or so. I was wondering if there were any problems that I need to look out for. It will probably be an automatic if that matters. I figured that this would be the best place to find something. So any help would be greatly appreciated.
~Austin
Old Dec 16, 2004 | 02:11 AM
PW01's Avatar
PW01
*The SOHC engine in the 01 is notorious for the timing chain "rattle" (had mine fixed under warranty).
*Valve body gaskets on some were over torqued at the factory, requiring a new gasket to smooth out shifting (warranty)
*Steel drive shaft had a slip yolk issue causing a thump upon take off. Grease slip yolk, or replace with 1 piece aluminum shaft.
Sounds like a lot, but not all trucks were affected with any, or all of the above. Just look for those issues when you test drive. Aside from those issues, Great truck. Good luck!
Old Dec 16, 2004 | 02:20 AM
B C fx4 Level II's Avatar
B C fx4 Level II
I Think the 01 still had the Pulse Vacume Hubs. A lot of people on this site are very unhappy with the p.v.h. 4x4 system.( not everybody but quite a few .)
Old Dec 16, 2004 | 01:16 PM
monkeychops
Cool, thanks for the info I'll be sure to look for that. Anyone else?
Old Dec 16, 2004 | 04:36 PM
Rockledge's Avatar
Rockledge
Actually, the PVH system was not used on the '01. Ford switched midway thru the '00 year from PVH to a "constant engagement" system on the Ranger.
