Sponsored by: Innova
Bazooka Subs
Old Dec 15, 2004 | 09:58 PM
fordtrucklover94's Avatar
fordtrucklover94
Bazooka Subs
I was looking in circuit city today and found some Bazooka 12" subs for under $50 and was wondering if they were worth my time. The number on them is Bazooka ELW12142. says 350 peak wattage, can't find rms, still looking.
Old Dec 16, 2004 | 08:12 AM
Muffinman's Avatar
Muffinman
350 peak is around 60~70 watts RMS. What is the SN Ratio and response range? What are the amp are you using to drive it?
With some of the numbers you can figure it out, But there is a reason there $50.00.
Old Dec 16, 2004 | 10:41 AM
fordtrucklover94
ok, i did a little research, the subs have an rms of 150, no amp yet, i can't remember the other stats, gone back home with dial-up, ugh, and can't do a lot of research, going out today to take another look at them, but i don't know if thats what i'm going with
Old Dec 16, 2004 | 12:53 PM
kens64's Avatar
kens64
Peak ratings have no relation to RMS ratings. A speaker could be rated 1000 watts peak but only handle 50 RMS. Peak is a number pulled out of thin air by most speaker builders.
That said, if you are looking for sound quality, there are better out there. For just bass, they do pretty well. For a 1st system, they are not bad. Put them in an enclosure that matches their specs, and most people would be happy with them.
Ported Enclosure 2.0 cu ft
Port Length 15.71 in
Port Diameter 4 in
port Frequency (Fb) 31Hz
Old Dec 16, 2004 | 11:18 PM
fordtrucklover94
Ok, I was looking again today and i found something i think i'm going to like better. I am not looking for competition quality subs, I'm looking for some decent subs to add some more bass to my system. Right now i have a 45wx4 Pioneer HU, with 20 rms, 220w Pioneer 6x8's with 45 rms, and am looking at some pioneer subs that are 150 rms, 600 peak. not sure on the other specs other than them being 12", I have all the info for boxes, just seeing if these subs are even worth my time looking at. For 2 they are 100, for 1 it's 70. I am happy with the rest of my pioneer equipment, and since i'm not looking for anything high powered, these seem great. Another question, I am new with subs, this would be my first set, and i was wondering what kind of amp's I should be looking at. also, would it be safe or even worth hooking subs up before an amp and then putting an amp in later? I mean, i plan on getting an amp before hooking them up, just kinda something i've been wondering/thinking about while i was looking at subs.
Old Dec 17, 2004 | 12:31 AM
kens64's Avatar
kens64
Subs need a strong amp, your head unit will not push them very well. Any amp with output around the RMS ratings of the subs will be ok, a little higher or lower really doesnt matter.
I would pick the Pioneers over the Bazookas. I've had really good experiences with Pioneer.
Old Dec 17, 2004 | 08:06 AM
Muffinman's Avatar
Muffinman
Be carefull about Comp. speakers. Some like SQL are not made to be played everyday.
Old Dec 17, 2004 | 12:17 PM
fordtrucklover94
Yeah, i'm not going with competition subs, as i said, i just want something to add a little more bass to my system. I think I will be going with the pioneers, I love my pioneer speakers and HU, so why not just top it all off with a sub. They seem to be what will fit my needs so i think they will be great. Thanks for ya'lls help
golfaddict73
2004 - 2008 F150
Jun 22, 2007 10:34 AM
fordtruckman
2004 - 2008 F150
Nov 25, 2006 11:15 AM
Fordbyford
13
Aug 30, 2005 11:16 PM
screwmank
1997 - 2003 F150
Feb 20, 2005 07:16 PM
ford5.8
43
Nov 27, 2004 01:31 AM
