AOD Neutral Safety switch..Replaceable???
Old Dec 15, 2004 | 04:07 PM
r7salvation's Avatar
r7salvation
Hey tranny experts..... my 89 AOD has an open circuit through the NSS (and no back-up lights ). There is a short pig tail plugged in next to the speedometer cable (about ten inches long) and the harness wiring coming from the firewall with a four wire connector plugs into it. I am almost sure this is the NSS but IS IT REPLACEABLE with tranny in the vehicle ????
Any info will be most helpful.
Old Dec 15, 2004 | 09:49 PM
Franklin2's Avatar
Franklin2
I don't know about the AOD, but most switches are mounted on the side of the tranny right where the lever goes inside. If you take the linkage off the side of the tranny, and the two bolts that hold the plastic switch to the tranny, they usually slide right off. They have a hollow shaft, and mount around the shaft going into the tranny.
koplinhagen
May 24, 2015 02:25 PM
koplinhagen
May 20, 2015 10:06 PM
moconnor603
Aug 25, 2012 09:02 PM
EffunFiddy
Apr 15, 2012 01:28 PM
Dads79
Jun 21, 2006 04:13 PM
