my oil is white
Originally Posted by JByrd1173
checked my oil today and it was white ,my poor poor 292,guess ill put a 302 in it after all.
any suggestions?
any suggestions?
A 302 is a good choice if you must replace that engine, you said white oil?? Can't say i've ever seen white oil, but i've seen yellow oil when a person has a craked head or block, ussually if it's only a blown head gasket, you get compression in your coolant, start that engine cold and look for bubbles with the radiator cap off, this means a head gasket is blown btween a block water jacket and the cylinder, but when oil oil is yellow and YIKES even gets as bad as white!! Sounds like a crack in one of your heads between Valve area and the water chamber in one of the heads, way to tell which head it is, listen, let it sit over night, then remove one spark plug at a time, and when you run into a plug that is damp, BINGO, that's the side with the cracked head, don't give up just yet, i would not feel to great if this happened to me, but i would calm down and use the steps i told you about in my post. You also have the option of having a silicone treatment done on your engine by a trucking (Diesel) repair facility. i'm sorry this has happened to you, but i do know for a fact in this forum, one guy recently bought 3 old scrap 292's and i'll bet someone in here can get you one head, i'm thinking your looking at a valve to water chamber crack in just one head on that engine, i told you how to tell which head it is, do that, the start a topic asking everyone who has a head for sale, after you remove the cracked head, i know someone in here will have one to sell you, also a machine shop can magnuflux that bad head and sometimes easily blow powered irin the crack and bake it, i'll bet it's not going to be all bad as you think, i believe that topic where a guy said he bought 3 old scrap 292's was titled "What is a Yblock or a 292 worth paying", back track and you'll find that topic because i remember it.Now wait till it's cold, then remove one spark plug at a time, now when you find a damp one, that's going to be your problem area, and a head for a 292 isn't all that hard to find and you can find one right here in this forum, after removing the head remember to let the users in here know what numbers and or alphabets are on the head so they know what year deries and type, and the side with the damp spark plug, after you remove that head you also have your chance to look for a cracked cylinder, but let's hope not....Janet
I wouldn't use that in any engine, full stop.
Usually does more harm than good. If I were you,
I'd check the t-stat and change the oil/filter, then
take it for a 1/2 hour drive, get it good and warm,
then see if the problem has returned, if it hasn't,
run the Y 'til it dies... then you can think about an
engine swap...
SteveL
engine swap...
SteveL
