Aerostar Ford Aerostar
Where do cable adjusters go??
Old Dec 14, 2004 | 09:09 AM
kpolly's Avatar
kpolly
My husband has been trying to fix the rear brakes in our 93 3.0 L. They aren't working at all. He's in the process of fixing the brake line and realized that he needs an adjuster kit. Problem is, he doesn't know where to put the cable adjuster on. He's new at doing brakes, and the auto shop wants to charge about $300 when the part only costs about $20. Also how do you properly bleed the brakes? Is it more difficult with ABS? Any info would help us out greatly.
Old Dec 15, 2004 | 03:19 AM
xlt4wd90's Avatar
xlt4wd90
Don't know about the cable adjuster, but there apparently is a trick to bleeding the brakes on a system with ABS. The best thing to do is to try to keep fluid in the reservoir as you're bleeding the rears so you don't suck any air into the lines between the master cylinder and the slave cylinder. The ABS mechanism is in there somewhere, and if you get air in it, it will be next to impossible to get it all out without using a special electronic jig that only Ford has. In that case, you WILL have to go to the dealer to get it done correctly.
Old Dec 15, 2004 | 09:02 AM
yendor's Avatar
yendor
kpolly
it could be that you have some were along you have lost pressure in your brake system and your distrubition valve has moved from center to one side.
Old Dec 15, 2004 | 01:33 PM
kpolly's Avatar
kpolly
no, it's not that. What happened was we bought the van a couple of months ago. We found out there was a leak in the brake line and the adjuster fell out from the shoes. My husband tried to fix the brake line himself but realized that the bolt to the wheel cylinder was rounded and couldn't get it out. So we took the van to the shop which they fixed the brake line and ended up putting in a new wheel cylinder ($200 dollars later). When they were there they noticed that the cable adjusters and cable guides were missing from both sides, I imagine that's why the adjsuter fell out. My husband said that he would fix it on his own since the parts only cost about $20 but now he's got to figure out how to put them back on. I imagine it's not hard but we don't want to overlook something that will cause damage later. Anybody have to put an adjuster kit on rear brakes that can tell us the process?
Old Dec 15, 2004 | 02:01 PM
copper_90680's Avatar
copper_90680
When I get home tonight, I'll post a picture of one side of the brake. The other side is similar. As for bleeding the brake, there is no special procedure for rear ABS. If you have both front and rear ABS, then it's difficult. I'll tell you all about it tonight.
Regards
Old Dec 15, 2004 | 07:48 PM
copper_90680
As promised, I sent you the drawings of the LEFT rear brake. Note that what they call the "secondary" shoe is actually the heftier of the two, since it takes more load.
Old Dec 16, 2004 | 09:31 AM
kpolly's Avatar
kpolly
Thanks for your help anyway copper. The forum won't let me email you back because I haven't posted enough yet. So, hopefully my husband can figure it out. I'll check tghe internet and see if I can find a good pic of a rear brake. Thanks anyway.
Old Dec 16, 2004 | 10:16 AM
copper_90680
Kpolly:
I sent you an e-mail. Check that, and you should see my e-mail address from there. E-mail me back to that address and I will get your address from there. Kind of a roundabout way, but that's the rule
Old Dec 16, 2004 | 11:13 AM
M.Herrington's Avatar
M.Herrington
from the manual.....
ÚÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
³ Item ³ Part Number ³ Description ³
ÃÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´
³ 1 ³ 2028 ³ Anchor Pin Plate ³
³ 2 ³ Ref. ³ Anchor Pin ³
³ 3 ³ 2261 ³ Brake Wheel Cylinder ³
³ 4 ³ 351467-S ³ Washer ³
³ 5 ³ 2296 or 2035 ³ Retracting Spring ³
³ 6 ³ 2200 ³ Secondary Shoe and Lining Assembly ³
³ 7 ³ 2A179 ³ Cable Guide ³
³ 8 ³ 2A178 ³ Self-Adjuster Cable ³
³ 9 ³ 2A637 ³ Parking Brake Lever ³
³ 10 ³ 2049 ³ Adjuster Lever Spring ³
³ 11 ³ Ref. ³ Pivot Hook ³
³ 12 ³ 2A809 ³ Parking Brake Cable, Left ³
³ 12 ³ 2A635 ³ Parking Brake Cable, Right ³
³ 13 ³ 2A176 ³ Adjuster Lever ³
³ 14 ³ 2041 ³ Adjuster Assembly ³
³ 15 ³ Ref. ³ Parking Brake Cable Housing Retainer ³
³ ³ ³ (Part of 2A809 and 2A635 Cables) ³
³ 16 ³ 2200 ³ Primary Shoe and Lining Assembly ³
³ 17 ³ 2A642 ³ Parking Brake Link ³
³ 18 ³ 2A094 ³ Brake Shoe Hold-down Assembly ³
³ 19 ³ 2A601 ³ Parking Brake Link Spring ³
ÀÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
Old Dec 16, 2004 | 11:35 AM
copper_90680
Hi M.Herrington:
Yes, that's exactly what I was trying to post, but without success. It might be helpful if they see the other picture with the difference between the primary and secondary brake shoes. Otherwise, they may put them on backward. Also, how did you put the picture up? I'm semi-illiterate shen it comes to these things
Old Dec 16, 2004 | 11:43 AM
M.Herrington
not sure which pic you're referring to, but as far as getting the picture up, type IMG inside [] then the image address.
Old Dec 16, 2004 | 12:37 PM
kpolly's Avatar
kpolly
You guys are great. I'm sure my husband can figure out how to put the shoes back on as he was the one who replaced the ones before getting the safety certificate a couple months ago. Thank you very much!! This will be very helpful, considering we now have the missing parts and know where they go!
Old Dec 16, 2004 | 01:07 PM
copper_90680
Hi M.Herrington:
Now I'm a complete illiterate What is the image address? I have the image as a JPG file on my computer, but it has no internet address. Where do I go from there? Thanks.
Old Dec 16, 2004 | 02:22 PM
M.Herrington
you will have to upload the image to somewhere on the internet, there are a few free photo hosting sites out there, just have to search
Old Dec 16, 2004 | 03:48 PM
BarryFS's Avatar
BarryFS
Try http://www.villagephotos.com they are free.
tsbrewers
Dec 7, 2024 03:25 PM
JMattyAK
Feb 10, 2011 05:36 PM
Joeskidoo
Jun 8, 2010 09:17 PM
JHoffman93
Dec 23, 2009 09:19 PM
DAV1972
Aug 30, 2008 07:57 AM
