Would this work??
Old Dec 14, 2004 | 09:07 AM
77460ford's Avatar
77460ford
Would this work??
To put this into context, the vehicle is a '77 F150 4X4 (460/C6) with the NP205. This truck has become a big street rod so forget about the front differential. Now after looking at the twin stick setup for the transfer case I was thinking I could install a rear gear ratio so the truck is setup for performance while in low (transfer case) and then have my highway gearing when in Hi (transfer case). Yes I understand I can't engage the front but I'm curious if the transfer case would take the abuse of the higher RPM. For my application it seemed cheaper than a gear vendors OD since I only need to change the rear gears.
Well it's your turn, what's going to go wrong? After a night shift the ideas always seem so good (then you wake up and wonder what the he** you were thinking!).
Thanks.
John.
Old Dec 14, 2004 | 11:00 PM
SoCalDesertRider's Avatar
SoCalDesertRider
The transfercase is not recommended to be in low range at speeds above 45mph.
Old Dec 15, 2004 | 04:02 AM
77460ford's Avatar
77460ford
Thanks
I knew it was to good to be true, back to saving for the gear vendors.
John.
Old Dec 15, 2004 | 06:58 PM
SoCalDesertRider
----back to saving for the gear vendors.----
Yeah, me too! I want an overdrive gear behind my C6.
flat4vw
Jun 22, 2011 09:04 PM
BlueOvalBud
Feb 14, 2010 08:25 PM
BlueOvalBud
Aug 29, 2009 10:12 AM
fairlaniac
Nov 22, 2006 07:31 AM
Junkyardslug
Offroad & 4x4
Sep 5, 2000 01:06 PM
