Sponsored by: Auxito
Brake Upgrade
Old Dec 13, 2004 | 08:22 PM
mcdev's Avatar
mcdev
Brake Upgrade
I am thinking about upgrading my brakes. I am tired of my current ones, always having probles - shuddering, excessive wear, smelling the brakes when I shouldn't, ect. I am thinking about drilled rotors and those ceramic pads. Had anyone done this yet? How big of a job is it and what special tools will I need? I haven't done a brake job yet so any advice, insight, suggestions about methods and products would be greatly appreciated. Thanks guys.
Old Dec 15, 2004 | 12:22 AM
2001gocougs's Avatar
2001gocougs
I installed cross drilled rotors with ceramic pads with severe duty front calipers. The stopping power is improved. Flushed the brake system at the same time. I will next install braided steel lines. There is sometimes more noise with these brakes but they don't fade.
It was easy to install them. I used the Chilton manual. I had to use a sledge hammer to remove one of the rotors due to rust.
Old Dec 15, 2004 | 12:30 AM
mcdev's Avatar
mcdev
Thanks 2001gocougs. What brands did you go with and how much did it run you?
Old Dec 15, 2004 | 01:07 AM
2001gocougs
Powerstop and I think it was about $280.00-$320.00 total for rotors, calipers, and new dot 3-4 fluid.
Ford'05HG
Aug 17, 2014 02:54 PM
gysgtbigdaddy
May 4, 2014 12:42 PM
Fuzzy Willy
2009 - 2014 F150
Jun 8, 2013 10:17 PM
akfishinguy
Dec 17, 2004 10:07 PM
