harmonic balancer on 302
I'm swapping an 86 302 into my 88 f150 ! The question I have is can I use the serpentine pulley system from my 88 302 on the 86 balancer? I've heard the older balancer is different in that it would space the pulley to close to- or to far away from the motor? I would just swap balancers but someone took the balancer off my 88 motor. Apperently they thought they needed it more than I did? If anyone knows if these balancers are the same please let me know. THANKS
ooops where did I get 351W?
anyhoo... you need to check the distance that the balancer sticks out, it might throw your alignment off. If they are the same, then you are fine using either the 88 & 86 balancer.
HEY guy's thanks for the info!! Since I didnt have the 88 balancer to compare the two I just bolted the 88 timing cover, waterpump, serpentine accessories,and lower pulley on the 86 motor before I put it in the truck. Every thing seems to line up just fine so apparently the balancers are the same.I wonder if the difference in the timing covers and water pumps is why people thought the balancers where different ?? Anyway,Thanks again guys!! MIKE
bigperm2
Sep 12, 2022 10:12 PM
ChrisAdams
Mar 12, 2011 07:09 PM
yellow 79
Apr 1, 2009 05:24 PM
medicpg
Jun 27, 2003 11:25 PM
Determan
Jun 23, 2001 07:02 AM
