302 misfire problem, need help!
Old Dec 13, 2004 | 08:29 AM
brennan carey's Avatar
brennan carey
Hi guys, need some help. I have a recently rebuilt 302 (1500 miles) with edelbrock performer rpm carb 750cfm (electric choke) performer rpm intake and performer rpm cam. Cast iron heads with 1.9 intake and 1.6 valves. roller rockers etc. I had the car on the dyno did 300hp at 4900rpm. Rev any higher and it just went dead. timming was advanced but it did not help. We suspected a ignition/ distributer problem took the car to a distributer guy who replaced the module (stock ford distributer with ignitor electronic conversion) and he also replaced the coil. This did not help..
I took th car to another mechanic who asked if I had replaced the valve springs when i did the engine. bingo... i did not! so he repaced the valve springs with Isky double springs for high RPM performance. I get the car back and now it revs to 6500rpm but at 2500rpm when "under load" it misfires. take your foot off and accelerate slowly and its fine. it only misfires at this rpm. need help as i dont know why this is now happening, as it was not an issue before.. I have taken it back to him and he has reset the tappets and is now blaming the distributer. I am going around in circles!
Old Dec 14, 2004 | 09:38 AM
Mike G's Avatar
Mike G
First off, welcome aboard!!
I obviously don't have an exact answer for you but it sounds like perhaps a carb setting issue. IMHO that is a lot of carb to start with for the motor.... Surely the more experienced will chime in for you.
--Mike
Old Dec 14, 2004 | 09:51 PM
tukes48's Avatar
tukes48
what kinda distributor you running ?? are u running an ingition box ? what type wires ? i had the same problem and the solution was i needed more voltage to the plugs. after putting an MSD ingition box and MSD Distributor and some accell 8.8 mm wires and a better set of plugs. never had a problem with high RPM.
But for the 2500 rpm misfire i would check the carb make sure that everything is ok in there. i think a 750 is to much carb that 302. i built one close to what u did and ran a 650 cfm on and that motor would RUN my 68 cougar like a rocket.
bigblue
43
Feb 20, 2017 10:11 AM
Blake12
Jan 25, 2016 08:08 PM
bigdan1979f-250
Oct 15, 2015 01:22 PM
nut behind the wheel
Apr 21, 2009 06:06 PM
52 f1 younggin
Aug 10, 2001 05:19 AM
