Dana 60 Axle
Old Dec 12, 2004 | 10:58 PM
oricle's Avatar
oricle
Dana 60 Axle
I have a 91 F250 right now, and have a I-Beam susp so I don't have a solid axle up front. I wrecked it a couple nights ago and saw that my front axle looked pushed back and bent. The right wheel is also totally off alignment it weeves out to the right. I was on ebay and saw a Dana 60 off a 79, front and rear axle up for sale. Would these fit on a 91 F250? If so do they require much modification to fit on, like are there kits for them?
Old Dec 13, 2004 | 05:58 AM
SoCalDesertRider's Avatar
SoCalDesertRider
The rear one will fit. Not sure on the spring width of the front one. A Dana 60 front axle from an '86-'97 F350 will fit though. You need the trac bar and bracket from the F350, all the steering linkage and the front springs.
Old Dec 13, 2004 | 08:38 AM
mark a.'s Avatar
mark a.
The spring pads are in different locations on the fronts.
Old Dec 13, 2004 | 05:02 PM
oricle's Avatar
oricle
Im going to be heading up to some junkyard around here and looking for a F350 with a solid dana 60. How much would you guys be estemating a axle to cost. And how would I go about replacing the front springs, do you have a site that lists them. And on the spring pads do they have them listed at any sites, and do you just weld thouse on? And on the steering. Do I need to replace the steering box, and everything up to the steering shaft or what?
Old Dec 13, 2004 | 09:16 PM
Scouder's Avatar
Scouder
Dana 60 front axles are typically $750-1000. I was walking through the junkyard one day and picked one up for $500, but most yards know what they are worth. I sold it one week later for $750.
-Scouder
