The 352FE Roars again!!
Old Dec 15, 2004 | 01:46 AM
WillyB's Avatar
WillyB
Pull the spark plugs and save your starter - but why not use a drill on the oil pump shaft?
Old Dec 15, 2004 | 07:58 AM
FERacing66's Avatar
FERacing66
Well I heard you have to have a special attachement to fit the oil pump shaft. I know the shaft is pretty far down in the block, I dont think I could fit the drill in there enough. I think ill try the starter method.
btw, I am running a Melling HV oil pump with a melling high strength drive shaft, I have heard that the ARP's are the best, will mine work all right? I dont want it too snap on me.
Thanks again
Old Dec 15, 2004 | 10:18 AM
PROSTOCK's Avatar
PROSTOCK
Use a 1/4 drive 5/16 socket and extension, driven by a drill motor, works great!
Old Dec 15, 2004 | 10:50 AM
gtex's Avatar
gtex
I used an old stock pump-shaft, mig welded the socket to the shaft. Then ground it smooth. The socket seemed to be a litle tight without grinding it down. This setup has little to no chance of dropping the socket in the pan....
Oh, and I think it spins counter-clockwise (looking from the top) with the drill.
Old Dec 15, 2004 | 11:35 AM
rusty70f100's Avatar
rusty70f100
Gtex is right. It spins counter-clockwise. That would be reverse on your drill. When I did mine I used a thin wall socket, 1/4" drive, with the extension in the drill. Leave the valve covers off to look for oil oozing out of the rockers.
Old Dec 15, 2004 | 05:35 PM
FERacing66's Avatar
FERacing66
Thumbs down Another delay
Okay, got some really crappy news, I just pulled the dizzy to prime the oil pump and I can see that a lifter galley plug (the one on top, closest to the dizzy) has come out, this explains my 10psi@2000rpm oil pressure reading. So I will be taking the intake off tommorw too see what other ones have come out. This time around I am going to tap the holes and put the screw in type. At first I was furious and I punched the wall, but I am so used to taking things back apart becasue I scewed up at something that it is no big deal. I figure that I can get the old plug out by draining the oil and trying to get it with a magnet. So its a big set back but thats the price of being a 16 year old self-taught FE engine builder. I wonder when the plugs at the rear of the block will be coming out?
One more thing, the plugs that you hammer in, is the open part supposed to be pointing out, or the other way? Gtex and rusty, what kind of oil plugs did you use?
Old Dec 15, 2004 | 06:19 PM
gtex's Avatar
gtex
I can't be much help there. Flatlander put those in the first time, and the local machine shop the second time (when I had #1 sleeved for that pushrod cup incident). I had the wrong pushrod cup size. So, I've been where you're at...hang in there. I do believe mine are the screw in type.
Old Dec 15, 2004 | 07:26 PM
tastyklair's Avatar
tastyklair
Take your time. The old saying haste makes waste is appropriate. You don't want to waste what you have spent so much time working on. Anything worth doing is worth doing right This is getting to corny, sorry!
Old Dec 15, 2004 | 09:42 PM
WillyB's Avatar
WillyB
You are doing fine - none of my kids would have been able to do what you have without massive help.
Experance is the best teacher, but it can be a bitch. All of us learned the same way, by making the same mistakes - or even worse ones.
Old Dec 15, 2004 | 10:29 PM
rusty70f100
Well I cant be much help either. I had my block completely reconditioned when I had it bored .030" over at the machine shop. New freeze plugs, new lifter gallery plugs, new cam end plug, new cam bearings, so on and so forth.
I do know they go concave side in though.
Old Dec 15, 2004 | 11:42 PM
FERacing66's Avatar
FERacing66
Thanks for the help guys. hey rusty, what kind of oil pressure are you running in your new 390?
B00M3R
28
Aug 16, 2014 09:35 PM
BlueOvalBud
16
Apr 29, 2011 12:00 AM
todd jo
Aug 23, 2008 07:10 AM
hoxiii
Apr 15, 2007 05:05 PM
FERacing66
Dec 19, 2004 07:08 AM
