spilling gas
Old Dec 11, 2004 | 09:43 PM
dino360's Avatar
dino360
Cool spilling gas
I have a 77 f150 4x4 that I just bought with the I6 300 and a 2 barell carb. I replaced the fuel pump and it started up just fine. The problem is that on the front of the carb are 2 nipples. One is on the passenger side and is for the inlet from the fuel pump. The other is toward the driver's side of the carb and had no hose attached to it when I bought it. When it started up, fuel started spilling from the second nipple. Should it be plugged or does it need to run to something?
Old Dec 11, 2004 | 11:22 PM
LxMan1's Avatar
LxMan1
Can you post a picture? Is the open part on the top of the carb? If so, it is a vent and the float is too high or there is something in the needle and seat.
Old Dec 12, 2004 | 03:59 PM
dino360's Avatar
dino360
Cool
I will take a picture with my digital cam and try to post it. I don't know how. Do I just click on the insert image icon and insert the adress like c/my documents/picture?
Old Dec 12, 2004 | 04:08 PM
LxMan1's Avatar
LxMan1
Go to user cp and create a gallery. It takes up less bandwidth. Also , click on the box to hide the gallery. It will still show up when your username is clicked on, it just won't show up in the gallery search for specific trucks.
Old Dec 12, 2004 | 05:18 PM
Chas1234's Avatar
Chas1234
If I didnt know anybetter I would say that it is the vent tube for the e-vap emissions - a picture is worth a thousand words though!
Old Dec 12, 2004 | 05:52 PM
dino360's Avatar
dino360
Cool
I think I did this right. It is in my gallery. The one in question is the one on the right as you look at the picture. It is toward the driver side. I believe it is the vent tube, but what do I need to do to fix this? Maybe the needle is just stuck from sitting and I can tap on it to knock it loose? I had stopped it up with a rubber cap but it seemed to run like crap. Thanks for the help.
Old Dec 12, 2004 | 06:23 PM
Chas1234's Avatar
Chas1234
I think a rebuild might be in order but maybe you could try to gently tap on the carb itself . After the rebuild I would keep that port plugged .
The doesnt look like the correct carb for your truck anyway.
If fuel is comming out of that port then the float is set too high or the needle is stuck .
Old Dec 12, 2004 | 06:46 PM
dino360's Avatar
dino360
Cool
I am not planning on keeping that carb or motor for too long anyway. Right now I am just trying to get it halfway running so I can move it around my yard and test out the 4x4 so I can be sure it is all working for the two projects this truck will be a part of. How involed would it be to adjust the float and get to the needle to be sure it is not sticking?
Old Dec 12, 2004 | 06:58 PM
Chas1234's Avatar
Chas1234
it is not very involved although I think you might have to remove the carburator inorder to take the top of the carb off . you adjust the float by GENTLY bending the tang so that it looks semi level . ( the exact spec I dont know) but if you by a rebuild kit it will show you . You may find that the float itself is sunk and causing the carb to over flow . Are you planning on swapping the engine out for another like a V8?
Old Dec 12, 2004 | 07:21 PM
dino360's Avatar
dino360
Cool
I am going to pull the engine to sell to a friend. The tranny and t case will be mated to my 360 engine and dropped into a 79 supercab. the C6 and 205 from the supercab will mate to another 400 that will be dropped into this particular truck. It will take a little time and patience, but I think I can do it successfuly.
Old Dec 13, 2004 | 09:01 PM
LxMan1's Avatar
LxMan1
Yes, that is a vent port. If gas is coming out of it, then either the float is too high or there is a piece of dirt in the needle and seat.
Oh, by the way, that is a 1bbl carb.
Old Dec 14, 2004 | 06:16 PM
dino360's Avatar
dino360
Cool
Thanks for the help and schooling on the one barrell deal. I am used to dealing with V8's which are usually a 2 or 4 barrell. I do appreciate it.
Old Dec 14, 2004 | 10:42 PM
LxMan1's Avatar
LxMan1
No problem, glad to help. Did you get it fixed yet?
Jklnhyd
Feb 22, 2014 11:24 PM
ohbrian
Oct 17, 2013 07:50 PM
HillBillyBuddha
WTB - Parts & other
May 20, 2013 09:06 PM
xirxious
Dec 18, 2012 08:32 AM
oem78
Jun 25, 2004 02:28 PM
