Unfixable Problem with Alignment?
This problem has been bothering me since my truck was new. My '02 F250 PSD has a slight pull to the right. It's more than what the crown of the road causes, as I've tested it by driving the center-line and it still veers right ever so slightly. It does not get noticeable worse when braking like most alignment issues do.
I've had the alignment checked (3) times by (3) different shops and was told it's "dead on factory specs". Most recently, I had a 3.5" hanger kit w/dual shocks installed. I also had them put on the optional adjustable track bar. Of course, they did an alignment afterwards. I was hoping that this mod would finally eliminate the minor, but irritating, steering problem. It didn't.
Do you kind folks have any ideas what could be wrong?
TIA,
Matt
Swap your front wheels and see if the truck pulls to the other side. If there is no change, swap wheels from front to back. This should eliminate wheels and tires as a cause.
Inspect your rear leaf springs to make sure that a leaf is not broken and that rear suspension is not sagged or shifted on one side. Check the rear axle u-bolts while you are under the truck to make sure that they are properly torqued.
Did your alignment shop check front to rear axle position? Since you have seen the problem from day one it is possible that the front and rear axles are not properly aligned. An alignment shop that works with lifted trucks would easily check this out.
Lou Braun
I've definitely eliminated tires. Also, the shop that did my lift checked all suspension components for breakage and found none.
They did not specify whether they checked the axle-to-axle position, however. This may be a possible solution because, when I up-sized the tires from stock to 285s, with the stock suspension in place, the left front tire would rub on the mud flap when I turned the wheel all the way left. The right tire did not rub. Hmmm......
I've also read that leaf springs with unequal spring rates can cause similar problems. Have any of you experienced this?
Matt
Dick
I understand that the truck alignment is "within specification" but is the geometery correct??? Alignment specs are a range of degrees that are acceptable for performance and wear, however a pull within the specified range is still possible. Do you have a printout of what the actual alignment numbers are for you ride?? Did they do a thrustline alignment so that the front end will accomodate any misalignment of the rear end?? It your Left caster is more positive than your right that could cause a pull, if your Right camber is more positive than the left that could cause your pull. if your front toe setting is negative, and not positive, that could cause a lack of straight line stability. get a printout of your actual specs and the book specs, most alignment places will adjust to your liking as long as they get paid!!
good luck, R.
good luck.
opps. i didnt see till after i replied that you eliminated the tires. oh well.
I would just make sure you are going to a good alignment shop, that can make all the difference. Those crappy chain alignment places equipment isn't big enough for most of our trucks.... they just don't have the experience for it.
Yes, the last place that checked the alignment did show me a printout and we compared them with book. All numbers were either perfect, or well within acceptable tolerances, so they said. As far as I know, they did not check the rear end.
On Dick's recommendation, I did some crawling around under my truck with a tape measure. I've determined that the left axle-to-axle is 7/16" wider than the right. Also, based on measurements from the rear frame cross-member to the center of axle tube, it looks like the left rear needs to move forward exactly 7/16".
With all of your help, I may have found the problem. Woo hoo!! Now, I just have to figure out how to fix it. It sounds like this "thrustline alignment" may be what I need.
Matt
if this truck has done this from new ,it may have had rail shipment damage.
A good bodyshop with a laser frame machine will be able to tell if you have a tweaked frame or bent axle tube.
i've worked in them,now since retired!
Rich
