Sponsored by: Real Truck
ABS light and over drive light
Old Dec 10, 2004 | 08:19 AM
RobertJohn's Avatar
RobertJohn
My ABS light stays on all the time and now the light on the over drive button blinks.. It isn't on but blinks until enough speed is reached to get into over drive. What causes these problems ?
Old Dec 10, 2004 | 09:10 AM
V10MARS's Avatar
V10MARS
That combo is usually caused by the speed sensor in the differ....
Old Dec 10, 2004 | 09:26 AM
Autobahn F-250 Lariat's Avatar
Ditto on what V10MARS said it is problably the VSS on top of the rear diff cost about $30 bucks if i remember correctly.
Old Dec 10, 2004 | 09:31 AM
RobertJohn's Avatar
RobertJohn
Wow.
Thanks, I just got out from under mine and found it. Since I live in the middle of no where finding one may be a problem. But on mt next trip to the city I'll pick one up.
Old Dec 10, 2004 | 05:24 PM
Munkey's Avatar
Munkey
Howdy RobertJohn! Good to hear from someone just up the road from me!
What's the nearest dealership to you? Access Ford?
Old Dec 13, 2004 | 07:08 AM
kenneBF250V10's Avatar
kenneBF250V10
If replacing the VSS works for you, great, but replacing it isn't always the cure, I learned that. I had a blinking overdrive light, replaced the VSS in the rear diff, did nothing. Ultimatley, I had to have the trans replaced, cost is a bit more than $30. If replacing it works for you, terrific, but be prepared if it doesn't, there is a variety of things that can cause the overdrive light to blink. Before you waste the money on a new VSS, I suggest you get the code read, could save $$$$ in the long run. This is only my opinion, but I am also speaking from experience.
BIGBAND39
Escape & Escape Hybrid
39
Mar 24, 2016 12:23 PM
Powerstoke73
Feb 28, 2016 08:44 PM
BigRed82
Nov 2, 2014 07:14 PM
psw2168
New Member Introductions
Sep 16, 2009 04:11 PM
